Old 12-24-2013, 07:35 AM   #1
ChickenRC's Avatar
Default Lipo comp. Brushed motors?
hi,
needed help finding a brushed motor that is lipo compatible, won't be used for racing so doesn't need to be race/ROAR legal.
that's all thanks. please help.
Got anything against chickens????? If you do, meh I don't care.
ChickenRC is offline   Reply With Quote
Old 12-24-2013, 07:39 AM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
Any brushed motor will work perfectly fine with lipo battery packs.
SteveM is offline   Reply With Quote
Old 12-24-2013, 08:35 AM   #3
ChickenRC's Avatar
surely they'd get hotter, as they are being used faster and with more power? I was just wondering if there were any in particular that worked well with lipo packs, or if i'd need a heatsink or whatever. So they'd all work fine? I'm just worried about heat problems, is all.
Old 12-24-2013, 08:41 AM   #4
oeoeo327's Avatar
Trader Rating: 74 (100%+)
The only difference is that they'd be used for a longer period of time because a lipo battery often has more usable capacity than their NiMh counterparts - that's really the only reason you'd have to consider problems with heat. If you were going to run 3S packs, THEN you might need to consider finding a motor suited to that purpose.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 12-24-2013, 09:38 AM   #5
cartix's Avatar
Trader Rating: 33 (100%+)
I use Lipos with Silver Cans for TCS.
Cars and boats, lots!
cartix is offline   Reply With Quote
Old 12-24-2013, 12:27 PM   #6
ChickenRC's Avatar
ok gys thanks for the help
Old 12-24-2013, 02:59 PM   #7
Send a message via AIM to JimmyMack12
hi,
Yeah, the motor doesn't care where the electrons are coming from, as long as it's getting them.
We ran NiMH/brushless in oval for a season or two, and some classes even stayed with brushed motors, even after LiPo became the "suitably-accepted" mode of power for oval racing.
In fact, I use a Photon2 DuraTrax brushed motor with my 4000mAh/1-cell LiPo in my Legends car.
JimmyMack12 is offline   Reply With Quote
Old 12-25-2013, 10:14 AM   #8
A bigger concern than the motor is the ESC. Make sure it has a LiPo cutoff circuit in it (or add an external one). You do NOT want to dump a LiPo battery down too low.
Kevin Marcy is offline   Reply With Quote
Old 12-25-2013, 12:14 PM   #9
ChickenRC's Avatar
it's ok, already sorted that.
http://www.modelsport.co.uk/hpi-sc-1...roducts/366078
