Old 01-20-2014, 06:43 PM   #31
edhchoe's Avatar
Trader Rating: 41 (100%+)
I also like stainless steel screws.
edhchoe is offline   Reply With Quote
Old 01-20-2014, 06:52 PM   #32
LasagnaCat's Avatar
Trader Rating: 143 (100%+)
Send a message via AIM to LasagnaCat
I don't use stainless, but I regularly find bent stainless screws on the rides that pass through here. I wouldn't put them anywhere critical, the black oxide seem sturdier for regular use.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 01-20-2014, 08:10 PM   #33
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by Bappe View Post
how much weight can be saved if changing all screws from std steel to aluminium?
need to shave off 25g on my car
Do you need to lose the weight to get down to the minimum weight? If so I wouldn't worry about it too much. I think you will notice it more if you eliminate as much weight as possible up high by replacing top deck screw and such and not worry about the screws in the bottom of the chassis.
To give you an example though. On my T4 '14 I got the titanium screw kit from gravity RC. It replaces all the screws above the lower chassis with titanium ones. It's 47 screws total and saves 9 grams over the stock screws. But the bigger benefit IMO is it lowers the COG.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-20-2014, 10:13 PM   #34
rc car guy's Avatar
yes i agree 100% however the highest thing on your car is the body.. so try less paint/stickers shoo goo and such
rc car guy is offline   Reply With Quote
Old 01-21-2014, 12:31 AM   #35
Odin544's Avatar
Agreed. That the biggest reason I switched to lightweight bodies. To get rid of the weight up high.
TriCitiesRC.com
Old 01-21-2014, 08:49 AM   #36
Xpress's Avatar
Buy Lunsford screws and be down with it. That is all.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
