CRC xti set up
CRC xti set up
Hi can any one give me a good set up for the CRC xti and where can I find a set up sheet?
I'm converting my XL so I have the inline at the mowe but I have the transverse conversion coming.
My inline setup is,
.50 front springs
.404 kingpin length
Green center spring, 30w oil
Old white side springs, just touching
10k in tubes
3.4mm rear ride height
3.2mm front ride height
Front tires at 42mm
Rear tires at 43mm
-.5 Camber
.25 tow out
.50 front springs
.404 kingpin length
10k in tubes
Front tires at 42mm
Rear tires at 43mm
-.5 Camber
.25 tow out
My set up for 17.5
.55 front springs
5° blocks all shims forward
Front brace
0° toe
0.5° camber
Almost no front droop
Black tires, half sauce
3.2 mm ride height
Old white center spring
30wt oil
30000 tube lube
.50 side springs just touching
6mm pod droop
Yellow tires, full sauce
3.4mm ride height
.55 front springs
Front brace
0° toe
0.5° camber
3.2 mm ride height
30wt oil
30000 tube lube
6mm pod droop
3.4mm ride height
There is a thread for this car...you can probably find more info there and/or get more help. Some of the CRC guys keep an eye on that thread so posting it there is more likely to get their attention.
http://www.rctech.net/forum/electric...2th-scale.html
My set up for 17.5
.55 front springs
Front brace
0° toe
0.5° camber
3.2 mm ride height
30wt oil
30000 tube lube
6mm pod droop
3.4mm ride height
.55 front springs
Front brace
0° toe
0.5° camber
3.2 mm ride height
30wt oil
30000 tube lube
6mm pod droop
3.4mm ride height
sadly there aint a whole lot of setups found online, mainly just in the thread that InspGadgt has linked
So where can I get a set up sheet then?
My set up for 17.5
.55 front springs
Front brace
0° toe
0.5° camber
3.2 mm ride height
30wt oil
30000 tube lube
6mm pod droop
3.4mm ride height
.55 front springs
Front brace
0° toe
0.5° camber
3.2 mm ride height
30wt oil
30000 tube lube
6mm pod droop
3.4mm ride height
Thanks mate for that.
Still can't get the set up sheet on the link.
Why?
Why?
