Old 12-21-2013, 03:12 AM   #1
Default Belt snap!
How often would a tc belt let go on average? I ask because my t2 belt let go the other day and i am not sure if i should put a couple of spares in the box! The track i run on is pretty clean, only a few tiny stones seem to get stuck in the belts per run. Cheers
Fly'n Fish is offline   Reply With Quote
Old 12-21-2013, 03:12 AM   #2
Oops, running stock that is!
Old 12-21-2013, 07:19 AM   #3
2xs
It wouldn't hurt to have a couple spares running outdoors. I have never run outdoor with my TC or TCX. But I still keep a spare just in case. Doubt I will ever need them, just nice to have the insurance if one was to snap from picking up a body pin or screw.
2xs is offline   Reply With Quote
Old 12-21-2013, 07:43 AM   #4
chasingthepack's Avatar
id had enough of the belts snapping,i went to my local p/o and picked up some wide rubber bands,since changing over i havent had one let go at all and i run on a very dirty track,it also gives a small amount of traction control as it stretches slightly then catapults you past the car infront,its like having drs,havent lost a race since rubber bands,they are rare but if you can get the red ones they are really suited to stock,in mod i recommend 2 of the beige ones
hope this helps
and i nearly forgot,to reduce friction spray them with wd40 before a run makes them more supple
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-22-2013, 12:54 AM   #5
Some cars just are really bad for this.
My Xray T2 007 (I had 2) gave me no end of issues with stuff getting in the belts/pullies.
My Xray 2008 & T3 have zero issues with belts.
Belts + small stones is never a good combo.
Check the pullies for damage as well.
1101 is offline   Reply With Quote
Old 12-23-2013, 09:24 PM   #6
Ok thanks guys, i have one of each f+r in spare now. I guess the idea would be to clean after each run. They are pretty good at sucking up little stones in my t2.
Old 12-25-2013, 12:24 PM   #7
ChickenRC's Avatar
hope this helps
are you serious???
Got anything against chickens????? If you do, meh I don't care.
ChickenRC is offline   Reply With Quote
