Old 12-12-2013, 11:27 PM   #1
Default Getting back up to speed
Hi there, i am getting back into TC racing after an extended break. I raced 17.5 stock with a t2 chassis (just a straight t2, ie not 007 or whatever), back of the pack type of racer and i am wondering how much difference a new chassis would make. Also, i have a tekin rs and a t2 era novak motor, how would those two perform in comparison to new technology?
Another question while i am at it, does anyone have a link to a single source of how to go about setting up a tc from scratch, ie basic chassis stuff (i have the xray setup book the chassis came with) motors and esc boost, brakes etc? There is tons of great stuff in these forums but hard to sift through for a basic racer!
Thanks in advance for all your help!
Fly'n Fish is offline   Reply With Quote
Old 12-12-2013, 11:35 PM   #2
Should be fine to get you started.
frozenpod is offline   Reply With Quote
Old 12-13-2013, 04:22 AM   #3
dan_vector's Avatar
Trader Rating: 27 (100%+)
Definitely run the kit you've got and see how you get on. Once you are back up to speed then you can decide if you wanna get a new chassis. My advise would be to rebuild your shocks and diff etc put new orings and seals in as they could've dried out or degraded during the storage.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-13-2013, 07:00 AM   #4
Suspended
If you can get a 12.5mm rotor in that Novak motor, and a top quality lipo/charger combo(Thunderpower), then you're good to go.... I also run an old chassis(tc4) in 17.5t blinky, and it holds its own against the new cars once the power is there...
bertrandsv87 is offline   Reply With Quote
Old 12-13-2013, 07:44 AM   #5
Regional Moderator
CarbonJoe's Avatar
If you don't have a Hotwire for the Tekin RS, find someone that does and have them load the current "blinky" firmware (no boost, no turbo), since virtually everyone requires blinky mode in every class except modified.
Check your old batteries, and get rid of them if they are puffy, or either cell is below 3.2 volts.
Just about every track also runs a spec rubber tire, like a Jaco Blue, Sweep QTS-32 "True Blue", or Solaris Medium (assuming you will be running indoor on carpet).
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-13-2013, 07:53 AM   #6
Thanks for the replies guys, i will check the rotor pick up some new tires for the t2. Re the batteries and charger, i have a swallow charger and 5000mah 30c yontungs. What would you say about those?
Old 12-13-2013, 10:38 AM   #7
Suspended
That charger and lipo battery are good for bashing only , not Racing.... You might be able to get away with the charger if you repeak quality packs before you race, but the Yontong battery are not up to snuff.... You already know what I recommend, so I won't repeat....
Old 12-13-2013, 10:46 AM   #8
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Ur t2 will work but the setup window is very small compared to the newer T4 cars this I do know for a fact . A local guy runs one with decent luck in 17.5 but he is running new D3.5 and batteries .
Run it till u can get back in the grove .
But for batteries get u some promatch batteries ! Very good price and top notch performance !
The 7200/80c packs r very nice and should last u for a long time .
Back to the T2, do what ever u can to make that car flex as much as u can. It seems the more flex the chassis has the larger Ur setup window will be on med-high traction racing .
Good luck
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-13-2013, 11:23 AM   #9
http://richardchang.com/hobby.php?topic=tcsetup
I love this website. Tells you exactly what changes will do what, which is awesome. Helps me a ton when I want to figure out what to do.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-13-2013, 05:25 PM   #10
Thank you all for the replies. Plan of action is:
New tires
New racing batteries and charger
New motor
Race time!
