Old 07-12-2005, 07:39 PM   #1
DIMO's Avatar
Default Overly Tight Front Belt
Hey guys i havce an FK04 it hasnt been raced in about 3months
I took it out yesterday but i noticed the front belt was Extremely Tight
Heres a list of what ive done..
1) Made sure no twists in belt
2)Made sure the diff hasnt slipped out
3) Checked That bulkdheads werent warped
Could it be coz i havnt raced in a long time that the belt has just gone tight
It is the Hi-Performance front skinny belt
Any Help appreciated thanks
DIMO is offline   Reply With Quote
Old 07-12-2005, 07:46 PM   #2
Actually its quite normal for a belt to tighten itself after a some time.Reason being ,when you run your car the belt will be loosen.However,after a long time sitting there,the belt returns to its normal lenght.Thats why you feel that it quite tight. Go run your car using a hot modified!I believe the belt will surely loosen up.
My 2 cents.
Ben.C is offline   Reply With Quote
Old 07-13-2005, 05:59 PM   #3
Tom
Tom's Avatar
yeah thats normal, just go run a couple of packs through it
Tom is offline   Reply With Quote
Old 07-14-2005, 02:00 AM   #4
DIMO's Avatar
Default Thanx Dudes
Thanx Guys, got me all worried. One other thing. I have a sort of clicky sound coming from the car, ive checked for rocks anyting pullies, belts,spur and pinion are cleaaaaaan, any ideas
Old 07-14-2005, 02:38 AM   #5
Maybe you can check you front CVs.Sometimes they do make chattering noises.It happens to me sometimes.That means I got to take out for maintenance...
Or you may have a very warped spur gear.run your car at low volts and see whether your spur runs true.Slight warp is ok,but not excessive warp,that will also produce sound and kills the tranmission efficiency.
My 2 Cents....
Old 07-14-2005, 02:53 AM   #6
DIMO's Avatar
My 2 Cents....
Just Checked it, WARPED TO THE S**T HOUSE
gpx-4 on-road FRONT BELT(newbie Q) Dave_x8 Nitro On-Road 3 12-04-2007 12:56 AM
Quickest way to change out front belt. Loveless Nitro On-Road 7 09-19-2007 08:50 PM
Front belt stripping ... Loveless Nitro On-Road 26 08-26-2007 05:11 PM
Belt too tight? The Black Kat Electric On-Road 4 06-14-2004 08:41 AM
Front one way on tight tracks lee82gx Malaysian R/C Racers 15 12-02-2003 08:37 PM
