roar legal rubber tires and inserts?
Roar doesn't have a "legal" tire, other than if you goto a Spec Tire race. In which you will be running the same tire as everyone else.
The 27 in the take-off is their temp. recommendation for that tire. Like a cs-22, cs-27, cs-32 and so on. Same with Sorex and RP. Each company list a tire for different Track temps.
As for inserts same thing. There are no "ROAR LEGAL" insert. At most BIG races you will be required to use a pre-mounted tire. (one that the manufactuer has mounted) That makes the racingthe same for everyone.
Hope this helps.
Hope this helps.
the manufatuers web pages may have them.
For take off try Schumachers web page.
