Old 12-09-2013, 07:32 PM   #16
Geezatec's Avatar
What Model JR TX you using? My last post check the EPA. 100% no higher. then recalibrate.
Geezatec is offline   Reply With Quote
Old 12-09-2013, 07:37 PM   #17
theproffesor's Avatar
Trader Rating: 58 (100%+)
Its a jr xs3 tx and a rs310 rx. Been using them for over a year now with no issues. Ive had 2 rx8's, an rs pro, and several other ESC's with no issues.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-09-2013, 07:40 PM   #18
It only displays this issue when a load is on the drivetrain. I dont see how epa would have anything to do with it.
Old 12-09-2013, 07:42 PM   #19
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Sorry I missed this earlier.
Make 100% sure you're A B C wires are routed correctly. This sounds like 2 are mismatched.
Another test:
Power off, remove the sensor wire from the esc side. Power on, give the car forward throttle..does the motor spin backwards?
[email protected]
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 12-09-2013, 07:58 PM   #20
I would also suggest re-soldering your wires even if they are in the correct order. I've had it happen twice now where everything looks fine but didn't work. Re-soldered the motor connections and presto it worked.
Old 12-09-2013, 08:12 PM   #21
The motor turn in the correct direction with sensor unplugged and kotor wires are abc abc. So I am at a loss right now. Thamk you for the help, ill be sending a pm.
Old 12-09-2013, 08:31 PM   #22
Is it possible that with the hotwire you accidentally disabled sensored mode? Does it behave exactly the same way if you unplug the sensor wire?
-Mike
Old 12-09-2013, 08:33 PM   #23
Geezatec's Avatar
Randy is the man, listen to his comments.
Old 12-11-2013, 12:50 PM   #24
Team Tekin
Randy_Pike's Avatar
You can't disable the RS Spec form sensored only mode. This esc is blinky mode period which is sensored mode. This of course unless you unplugged the cable then it will run sensorless.
I've spoke to him since and it appears the sensor board is at fault. A new one has been dispatched to him.
This is another great time to discuss the data logging. Simply data logging this "issue" allows for the user to email us the file for us to inspect and help see what's going on with the system.
Another great feature of all our Gen2 esc's
Old 12-11-2013, 08:13 PM   #25
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Would the RS Spec be able to handle a 10.5T in 1cell WGT and 13.5T in 1cell 1/12th scale?
No Rx booster needed, all run on 1cell
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-11-2013, 08:25 PM   #26
I would like to thank Randy and Tekin for their help trouble shooting the issue and sending out the parts to correct it. Tekin customer service is hands down the best I have experienced. This issue has been resolved in less than 2 days. I cant wait to get the parts and get the car on the track.
Thank you
Bronson
Old 12-11-2013, 10:06 PM   #27
dan_vector's Avatar
Trader Rating: 27 (100%+)
+1
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
