3300 vs 3700/3800 Size >
Old 07-12-2005, 12:58 AM
Pinion King's Avatar
Default 3300 vs 3700/3800 Size
I brought a GP-3700 for my car (Tamiya Surikarn), and get home, build it go to drop it in the car, and realise that the cells are bigger. And in order to fit i must hack half the car apart, and i am not doing that.
Now my dad's got it (Tamiya TB-02)
Just wondering are the 3800's are smaller?? Or the same??
Thanx.....PK
Pinion King is offline
Old 07-12-2005, 01:00 AM
2-Bad's Avatar
Trader Rating: 24 (100%+)
Thanx.....PK
Same size I believe......
2-Bad is offline
Old 07-12-2005, 05:15 AM
mudpuppy's Avatar
IB3600 = 43.2mm x 22.3mm
GP3300 = 43.2mm x 22.6mm
IB3800 = 43.2mm x 22.9mm
GP3700 = 43.2mm x 23mm
mudpuppy is offline
Old 07-12-2005, 10:38 AM
mwcet8k's Avatar
Does ROAR or IFMAR place limits on the dimensions of cells? Seems like this is an ongoing problem. A chassis manufacturer builds a chassis for certain cell sizes, then a battery manufacturer releases cells that are too big for them to fit in that chassis.
mwcet8k is offline
Old 07-12-2005, 10:59 AM
Trader Rating: 18 (100%+)
Yes, ROAR does have a limit and I don't know what it is but I do know that there is a discussion on the 3700's and 3800's because they don't meet ROAR's specs. You can look up the exacts on ROAR's website.
Chris Brown is offline
Old 07-12-2005, 11:56 AM
Baja's Avatar
Isn't more of a trend brought on by the power tool market for longer run times and more power? seems that batteries are getting bigger every time the come out with a new cell.
Baja is offline
Old 07-12-2005, 02:11 PM
ChrisP's Avatar
According to ROAR dimensions 43x23 none are legal....the diameter is the big difference witht he new cells and they are still below the legal limit
ChrisP is offline
Old 07-12-2005, 02:29 PM
hobbipro's Avatar
Trader Rating: 21 (100%+)
I wonder if they next generation 3700's and 3800's will get smaller. I remember the first batches of 3000's and 3300's being larger than the current ones we use by 1mm. My current 3300's fit into every R/C I own, buying just one of these 3700/3800 battery packs would mean modifying every one of my chassis, But then trying to use a 3300 again without it being loose..... thats the problem I have with them.
hobbipro is offline
Old 07-12-2005, 08:52 PM
Same problem as mine.
The GP3300's are a great fit, they don't move around, nothing.
To fit the 3700's i have to file down the battery slots in the chassis, file down the holders at either end.
Old 07-12-2005, 11:36 PM
ford_racing's Avatar
do the 3700 / 3800's really fit inside your TB02 without modifications?
ford_racing is offline
Old 07-12-2005, 11:56 PM
Yep
Old 07-13-2005, 12:27 AM
That explains why I had such a hard time squeezing my 3700s into Shrink tupe!!!Thought I know its more larger than the 3300s,but didn't know they were so much bigger...
That was great info.Thanks Dude...
Ben.C is offline
Old 07-13-2005, 01:29 AM
DORIFT's Avatar
Anyone tried to fit the optional battery tray from a Yokomo BD that supposely are designed for 3800 sized batteries?
DORIFT is offline
