Old 09-04-2002, 05:08 PM   #1
Peter Busch's Avatar
R/C Tech Charter Subscriber
Default Foam tires
What kind of glue do you use for fixing chunks? I tried some Elmers acid free rubber cement which doesn't hold very well. I'll try some SHOO GOO tonight and see how that goes, it seems to work for everthing else.
Peter Busch is offline   Reply With Quote
Old 09-04-2002, 05:27 PM   #2
i have used super glue to fix chunks, butthe problem with it is that the foam wears down and the super glue doesnt so you have the hard pieces left as the tire wears.
Jarrod Langlois is offline   Reply With Quote
Old 09-04-2002, 05:52 PM   #3
CA holds well but it also soaks in and makes a hard spot on the tire, not good.
Old 09-04-2002, 07:20 PM   #4
spongebob, I used some TRC glue a couple times last winter to fix chunks. I'm not sure where to get it, I used some of Jason Klein's, so he'd probably know. It worked very well, held together great and dried very soft and flexible.
JeffC is offline   Reply With Quote
Old 09-04-2002, 08:24 PM   #5
robk's Avatar
Trader Rating: 22 (100%+)
If you want to use something similar to what TRC uses, get 'contact cement'. A brand name is Weldwood, there are others. You can get it at the hardware store.
Mostly i just super glue chunks back in though. Works fine
Old 09-04-2002, 09:31 PM   #6
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Super glue works good for repairing foam tires......just dont go to over board on the glue so you have a hard spot. Heck I've had to use CA on brand new TRC tires out of the package .
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 09-04-2002, 11:49 PM   #7
Trips's Avatar
Trader Rating: 16 (100%+)
The best glue I ever used for chunk repair was TRC's tire glue. It's a contact cement made for gluing foam tires to the rims. It stays flexible, so the repaired tire doesn't develop a funny wear pattern, yet the repaired chunk stays in place.
Tower still sells it, so your local hobby shop can likely get it too. It's TRC #902. Here's a link to it on Tower's website:
http://www2.towerhobbies.com/cgi-bin...1&I=LXJM85&P=7
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 09-07-2002, 06:54 PM   #8
I agree TRC tire glue is the best to use.
Chris H is offline   Reply With Quote
Old 09-07-2002, 08:18 PM   #9
Thanks, I will pick some up.
Old 09-09-2002, 04:54 AM   #10
RC Nitro's Avatar
Thanks for the tip Trips. I will get my track to order some. Been using CA myself. Had a bad blowout sat, lost 3mm in the center of the tire in a race. Brand new, still at 60mm. Had to have happened in the begining as the chunk was smooth all around.
RC Nitro is offline   Reply With Quote
Old 09-09-2002, 07:35 AM   #11
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
If you use thin CA it will soak into the tire and make hard places like was mentioned earlier. If you use medium or thick CA it usually just stays on the contact patch of the repair and all you see after it wears down is the thin line of glue.
BigDogRacing is offline   Reply With Quote
Old 09-09-2002, 07:46 AM   #12
RC Nitro's Avatar
Thanks BDR. I have both and a truer so I will try on one of my older tires and see. I usually glue and then true to remove large area's. That 3mm hole is a pain though. Hate to lose a new tire!
foam fk05 chasis and foam tires. Branden Moody R/C Items: For Sale/Trade 34 10-09-2007 12:20 AM
What type of foam material are foam tires made from? pirate Electric On-Road 2 04-20-2007 09:40 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Foam Tires Jye Rookie Zone 1 04-17-2005 05:47 AM
Jaco Foam Tires & Fast Tires Foam, Brand new. MugenMTX3Kid R/C Items: For Sale/Trade 11 01-03-2004 01:53 PM
