Old 07-12-2005, 02:07 AM   #16
fjm9898's Avatar
well i dont think you would have to have the MS because then you would have two MS chassis but yea i do argree you would at least have to have the suspension upgrade
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 07-12-2005, 03:10 AM   #17
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally Posted by Besercoe
I apreciate that we cant always have the latest and greatest, but if you cant afford the $80 conversion would you then be looking at getting a $200+ Chassis conversion?
Why i don't buy the LWT suspension is because i ONLY run on carpet and it's pretty wide spread that the old suspenion performs better on carpet tracks. I will probably try the LWT suspension this winter though.
Also 2mm wont make a difference, you have more adjustment than this on the std car anyway, as i said earlier you should be able to fit the old skool suspension, but you just wont have the range of wheelbase adjustment as you would with the original chassis.
Then it's a problem that's very easy solved with some grinding and countersunking.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 07-12-2005, 04:13 AM   #18
DORIFT's Avatar
$200USD sounds very reasonable considering the amount of parts you will be getting. I was expecting somewhere between $250-$300USD.
Can't wait for this upgrade, it will make the 415 the perfect belt drive on the current market.
Comparing the MS-X of Satoshi's and the normal MS, the two main chasis looks identical. Oh well, it will always be good to keep a spare chasis in the pitbox.
DORIFT is offline   Reply With Quote
Old 07-12-2005, 05:29 AM   #19
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
Does the MSX conversion can be installed in the normal 415?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 07-12-2005, 06:17 AM   #20
90% of the thread has been about if it can be fitted on a regular 415, just read
Old 07-12-2005, 06:36 AM   #21
KREATOR1's Avatar
well, theres no Yes or no yet , just some ideas and comment from drivers.Lets see when its out.
I dont really like the old arms. I rather stay with the regular 415 (04 arms) if the conversion does not fitt.
Old 07-12-2005, 06:41 AM   #22
raving-monkey's Avatar
Send a message via MSN to raving-monkey
ok, this is from tamiya.
the conversion will work with the standard 415 if you have LWT suspension
raving-monkey is offline   Reply With Quote
Old 07-12-2005, 06:54 AM   #23
KREATOR1's Avatar
too bad than.
Old 07-12-2005, 09:54 AM   #24
rtypec's Avatar
Last time I looked, the chassis is different. There are small differences here and there. I'm not sure about bulkhead screw locations, but I believe that they are not the same.
rtypec is offline   Reply With Quote
Old 07-12-2005, 02:30 PM   #25
TryHard's Avatar
Originally Posted by odawg315
the conversion kit comes with the lower chasis, wich im assuming is the ms chasis, wich means you wont be able to use the old suspension with it cuz the ms chasis has the pivots mounted 2 mm closer.
what id like to know is if the ms owners can just buy the bulkheads, or is the actual chasis and uprights different as well, im hopping to just get bulkheads as i just purchased a spare ms chasis.
AS i understand it, the chassis is 2.5mm thick, without the screw holes for the chassis posts. Also, from the images so far, the shock towers (at least the front one anyway) look distinctly different to both the MS and Std tower, more like Marc R's prototype one...
Still, hopefully I'll have enough funds for the conversion when it comes out....
Later
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-26-2005, 03:43 PM   #26
V12
V12's Avatar
Any new informations on release date and price?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 07-26-2005, 06:36 PM   #27
maxepower's Avatar
Exclamation RE: 415-MSX conversion
Last I heard it will be released in September!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 07-26-2005, 07:28 PM   #28
Kevin CBR's Avatar
The MS-X chassis will be different if not just for the rear bulkheads. The MS-X bulkheads are longer and probably different screw locations. Since the MS suspension pin is 46mm compared to 48mm for the regualr 415, and you have more than 2mm in spacers, you should be able to mount a regular suspension. The difference might be where the droop screw goes through the A-arm and if it will still hit on the chassis.
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 07-26-2005, 07:45 PM   #29
TryHard's Avatar
just got this from rainbow ten...
Dear Sir,
Thank you for your E-mail.
So far, TAMIYA JAPAN has not announced about the release of TRF415MSX conversion set.
We will update our page when they do.
Rainbow Ten
(Your E-mail was replied by Mr.Nao :Information desk)
Interesting....
Also I doubt if the bulkhead screws are in a different position, given the cost of remanufacturing such items (with regard to tooling etc). To me, the MSX bulkheads look to be based on the MS bulkheads, with the chassis mounting holes in the same place, and the major difference is in the upper part.
New Tamiya TRF415ms Jomsy R/C Items: For Sale/Trade 0 07-19-2006 10:04 PM
Tamiya TRF415MS!! $225!!! Core Creations R/C Items: For Sale/Trade 4 04-02-2006 10:20 AM
Tamiya TRF415MS x2 dale2176 Australia For Sale/Trade 8 03-06-2006 12:39 AM
Tamiya TRF415MS LE mihel R/C Items: For Sale/Trade 24 12-13-2005 03:06 PM
Tamiya TRF415MS protouring R/C Items: For Sale/Trade 5 06-20-2005 08:45 PM
