Old 12-03-2013, 09:29 PM   #1
R Doyel's Avatar
Default Body Mounting Discussion
I've never really found a mistake proof way to mount bodies. I've always sort of done my best. In some cases I get it wrong and really mess up a body. I just recently had two TC bodies painted and am ready to mount them. I really want to make sure I get these right....
I'd appreciate if people could share some helpful tips on how to mount a body successfully. Thanks!!
R Doyel is offline   Reply With Quote
Old 12-03-2013, 10:13 PM   #2
Scott B's Avatar
Trader Rating: 43 (100%+)
I like adding as many wheel spacers as in can to widen the car so it will press against the inside of the body centering it. Then just adjust it forward or back to line up the wheel wells. Then I use a pen to try and draw around the body posts on the inside (Removing the foam bumber helps in the front), sometimes its tricky to hold the car with out the body moving and mark the holes.
Also if you have a beat up body that lines up the way you want it to, you can cut it up and just use the upper part with the holes as a template.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 12-03-2013, 10:27 PM   #3
JimmyMac's Avatar
Wow, first I heard of the wheel spacer idea. I like it! Thanks!
I usually use an old body as a template and keep it around for future bodies.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-03-2013, 10:35 PM   #4
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Indeed. Simple idea that sounds like it is on the money. Will have to try that next time around... thanks "b" for the suggestion.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 12-03-2013, 10:35 PM   #5
Start slow with the post holes. Go like 3mm, check it, 4nm, check it, etc. If you're off by a bit, you can move the hole if it's still small.
-Mike
Old 12-03-2013, 10:41 PM   #6
Trader Rating: 27 (100%+)
Once you've got a body that you've cut and mounted perfectly, you could cut the top half of that car body off when it's trashed and use it as a diagram for your next car bodies. It's pretty much how I drill the holes for every single car I have now. I've got one diagram for each car and just use it every single time. It's quick, painless, and will always give you the correct mounting holes.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 12-03-2013, 11:17 PM   #7
Try these to help locate the body posts: http://www.rc-mushroom.com/product_i...th-led-p-21961
Simon
Team_Krusty is offline   Reply With Quote
Old 12-04-2013, 01:47 AM   #8
daleburr's Avatar
Make the holes and cut the shell out before getting it painted. Makes the job 100 times easier.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 12-04-2013, 04:33 AM   #9
Quantra's Avatar
If the body is painted I use a strong light like my pit lamp or a decent torch and shine it under the shell so I can see where the body posts come out. Also cutting the posts down as short as possible or even using a spare set cut down further can help getting the holes in the right place.
Vince Coleman
Quantra is offline   Reply With Quote
Old 12-04-2013, 06:35 AM   #10
Jorge T's Avatar
Spec R makes these nifty body post locators http://www.spec-r.com/default/index....roducts_id=535
RSD
Jorge T is online now   Reply With Quote
Old 12-04-2013, 07:40 AM   #11
ThePanda's Avatar
Trader Rating: 65 (100%+)
Yep. Sometimes I will put a little bit of grease on the body posts, and lower the body on slowely, and it will contact the posts, leaving a mark to reaM out.
ThePanda is offline   Reply With Quote
Old 12-04-2013, 10:48 AM   #12
Wow those are pretty trick, but I don't see what size posts they fit?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 12-04-2013, 10:59 AM   #13
Send a message via ICQ to JiuHaWong
Simon
Nice!
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 12-04-2013, 10:59 AM   #14
I think 3mm(?)
Old 12-04-2013, 11:10 AM   #15
Originally Posted by JiuHaWong View Post
I think 3mm(?)
I was guessing 6mm, I sent them an email and will repost the answer here when I get a reply.
Cheers, Jeff
