Old 09-07-2002, 12:57 PM   #31
dtm
dtm's Avatar
Send a message via ICQ to dtm
Well, I finually got round to running the GT7. Was using a 9x2, started with drive freq of 11khz which is the normal frequency I use on the Cyclone TC. The GT7 felt noticably smoother, not less punchy, but just smoother.....after finishing a pack of GP3300 it was "luke" warm to the touch which is quite good with outside temp of around 30deg C, some ESC come off the track ready to fry a egg!!
I also tried the 15khz and this made the car very linear...again, not bad at all. There are no real flat spots on the throttle curve.
Run time was pretty much the same...(I don't honestly believe remarks like "I got an extra 30s runtime!!...normally just means that the person wasn't driving as agressive!)....
All in all I am very happy with the GT7....well done Novak!!!!
dtm is offline   Reply With Quote
Old 09-07-2002, 01:00 PM   #32
dtm
dtm's Avatar
1 thing though...the little plastic clip to hold on the cap....its best to shoo glue this in place....I took a bump and the clip came flying off.....the cap was facing inside the car!!!! To put it back on you have to remove the ESC which is a bit of a pain...shoo glue should sort this out!
Old 10-26-2002, 11:25 AM   #33
lonestar1127's Avatar
dtm....for the GT7 did u shorten the cap wire??
lonestar1127 is offline   Reply With Quote
Old 10-26-2002, 12:18 PM   #34
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Boomer
sorry, not the ESC, but any word on their module for the M8??? The one that's in BK's radio. . .boy would that be nice!
The word I've been given is Late Nov, Early Dec.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-26-2002, 05:00 PM   #35
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I love my gt7 i am on the smooth mod profile for stock and it still felt awesome. will switch over to stock for now.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-27-2002, 02:14 AM   #36
dtm
dtm's Avatar
I couldn't be asked....I just mounted it on the other side of the ESC so the cap wires ran across and below the power wires!
Old 10-27-2002, 02:46 AM   #37
thanx for yr reply.....
btw wat mode u using for yr 9x2??
Old 10-27-2002, 03:35 AM   #38
dtm
dtm's Avatar
Mode 2 gives plenty of punch and is also very smooth!
Old 10-27-2002, 03:52 AM   #39
icic...i will try it out.....
thanx anyway
Old 10-27-2002, 04:20 AM   #40
black-knight's Avatar
R/C Tech Charter Subscriber
Just a few notes on the GT7...
I drive for an importer of Novak and have been running the GT7 for a while now:
1. Brilliant speedo very smooth, great setup procedure.
2. Consider running two or three capacitors, when running Sub 10 winds in hot conditions, the capacitor can get too hot and fail...if the cap fails the speedo will overheat. A fellow racer of mine has melted a GT7 with a 6 turn, on a short track.
In the lower end of the throttle range the cap is charged and discharged, overworking the lower end of the throttle range works the cap hard.
When we contacted Novak they suggested the extra caps to help with cooling, the lastest batch of GT7 also have a large gauge wire connecting the capacitor.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 10-27-2002, 05:10 AM   #41
Moderator
Thank you for the info Black-knight. I will be running hot ones today.
SMC Racing
Old 10-27-2002, 05:14 AM   #42
black-knight... the extra capcitors is for the esc or motor?!?
Old 10-27-2002, 06:48 AM   #43
what's the difference in selecting a higher freq range against a lower freq??does it has to do with more torque or smoother power band??
TIA
fReShJiVe is offline   Reply With Quote
Old 10-27-2002, 10:01 AM   #44
STLNLST's Avatar
Trader Rating: 21 (100%+)
TIA
The higher freq will be smoother on the throtle which will give a feeling of less punch because you have to pull the trigger more to get it up to speed...where running the lower freq will have a feeling of more bottom end punch which will get you up to speed quicker with less trigger pull.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-27-2002, 05:16 PM   #45
esc
J Concepts BJ4WE CHEAP!!! NIP NOVAK 10.5 & Novak 4300 w/Sintered Rotor Zac R R/C Items: For Sale/Trade 15 02-13-2008 06:13 PM
LRP Sphere tc, Novak 13.5pro, Novak 10.5 pro, Novak 13mm rotor theisgroup R/C Items: For Sale/Trade 9 01-08-2008 11:21 AM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
For Sale Novak 3.5 brushless motor with Novak Heat sink $60.00 SHIPPED!!! Marcos.J R/C Items: For Sale/Trade 14 06-24-2007 08:29 PM
Rivergate RCD30, Novak Millenium Pros, XXX4G+, XXXTMF, lehner/novak BL Jman-x R/C Items: For Sale/Trade 1 09-14-2005 10:51 PM
