Old 11-29-2013, 04:35 PM   #16
the first tamiya was the mercedes clk gtr shell and the chassis was TA03R.
what do you mean the foams get chewed up? you mean they get thinner?
yes i did meet my local clubs but they run nitro 1/8 on a quite small track. I dont see anybody doing touring because they do speed runs.
catalzzy is offline   Reply With Quote
Old 11-29-2013, 04:40 PM   #17
Suspended
Be sure of yourself, not confused, and get an Awesomatix A700 evo !!! It with handle all mod motors without worrying about debris on the track.....
If you're low on cash, pickup a tc4 tub chassis, and throw in a carbon driveshaft and LCD(#losa3344) drives to run mod motors.... Enough said ! Belt cars are way too messy !!!
bertrandsv87 is offline   Reply With Quote
Old 11-29-2013, 04:51 PM   #18
Suspended
Here you go buddy, it's a beast:
Http://m.youtube.com/watch?v=Wy-4Rm2v78I
Old 11-29-2013, 05:10 PM   #19
Suspended
Smile
And they say shaft can't handle mod speed !!! Give me a break !!!!
Here you go:
Http://m.youtube.com/watch?v=MtrS_J0t7OQ
Old 11-29-2013, 05:16 PM   #20
ThePanda's Avatar
Trader Rating: 65 (100%+)
I mean they can get chunks ripped out of them. So you are turning, and the car gets bounced by a pebble, come back down, hit a crack wrong, chunk gone. stuff like that.
for foams you want a very smooth, flat surface with no debris. so on a brand new swept parking lot should be fine.
ThePanda is offline   Reply With Quote
Old 11-29-2013, 08:17 PM   #21
snoopyrc's Avatar
That's why they hold up great on carpet, but come apart on asphalt with any debris on it.
Sounds like you do want to race. And there are a ton of kits out there that are excellent performers. Including the Spec-R and the Sakura. Tons of things to consider starting with what has the best parts support, setup support, and what is easiest to use.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 11-30-2013, 07:48 AM   #22
thanks for the advice. seems rather intriguing to buy a belt drive. How is it spec r s1 is better than sakura xi or zero?
*off point* I have one 3.5t motor lrp x12 non-octa wind and what bearing size should i get and what kind of bearing is best? i think i lost the manual or something.
Old 12-01-2013, 06:30 AM   #23
Get the Spec-R R1. Good luck!
cheapskate.brok is offline   Reply With Quote
Old 12-01-2013, 06:44 AM   #24
tak4's Avatar
I've had really bad experience with the Sakura... this comes from a fan of the car who trekked it before it was release. Just look at who started the Sakura XI thread.
Here's a writeup i did which covers the Sakura a bit.
http://www.racereadyrcs.blogspot.com...d-history.html
Nova powered MP9 Tki3
Hobbywing powered Kyosho MP9e (Tki3)
Orion powered Xray T4'14
Driven with Sanwa M12
tak4 is offline   Reply With Quote
Old 12-01-2013, 10:33 AM   #25
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Here you go:
+1 💪😃👍
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 12-02-2013, 02:51 AM   #26
would a 26mm front foam and 30 rear foam fit the spec r s1?
i have been seeing the hex hubs and they come in different size... what difference does it make if its little bit bigger? i thought the rims are compatible with standard hex hubs?
the solid axle front can be replaced with another gear diff and makes two gear diffs? and the parts from xray ranging from t1 to t4 2014 are compatible with spec r s1?
Old 12-02-2013, 04:11 AM   #27
Suspended
The Spec-R S1 and Sakura Xi Sports are essentially the same car. There is not much different between either of them, and they are both equally as quick. I started with a S1 and now have 2 Pro Specs, I have friends i race with who have the Xi Ultimate and Sports and they all go well. Pick either one, you will be happy.
30mm foam will go on the rear, I race in a 10.5 foam on road class and use 30mm rears. Just change the shock mount positions and all is well. Yes you can replace the spool with another gear diff, I run gear diffs in the front of both my cars, as i do not like how the car rotates with a spool. Its just a feel thing for me.
RogerDaShrubber is offline   Reply With Quote
