new types of touring cars
#31
I had a guy I race with who does a lot of offroad prototype builds CNC mill me out a few new top decks and battery tray for the JRX-S to give it some flex. It's still a bit tight but the new deck/tray combo lets me run a thick shorty LiPo with bullet plugs with room to spare.
#32
thats because its more efficient, by a fair amount, you put a tc4 and a new car in the hands of 2 equal opponents ill gaurentee the new car cars comes out on top, assuming that the motor they are running is 17.5 or higher. also a newer trend that happened was the smaller shocks, and smaller shock towers, which lowered the cog, id like to personally see less rotating mass especially in the djc, cvd/a its alot of extra weight and we can surely reduce it and that will in turn allow our cars to go faster, with less heat
#33
You can spend all the money in the world on having graphite this, and titanium that, with a million settings, but the fact is, if you car has been designed well from the factory(with few but important setting options only) + is very efficient, it will be extremely hard to beat in stock type racing.
#34
Rule change will be the main thing to change chassis design.
The majority of chassis are 'similar' as they follow the most race proven layout to base a touring car on. The fact that they look similar from a casual glance means nothing. I can sit down with a 417 and an Xray and they handle very differently.
These cars are refined pieces of machinery, where every millimetre counts.
The awesomatix is a fantastic piece of kit, and I have a buddy who is loving his. But overall when you look at results, its no more successful than any of the current breed, if it was destroying them on the track then everyone would be looking at changing to that layout.
#35
The trf415 did not come out on top, the tc3 did !!! The tc3 ,shaft design is everywhere in all durable Rc toys, drifting kits, winning kits, mini Rc cars, Gt cars 8th scale(no belts here), and all the real 4x4 cars that haul all you overweight racers to the track.... The shaft drive is universal, while the belt drive is limited to some Rc classes.... Even boats, helicopters, airplanes, flying saucers, use shaft not belt !!! LoL!!! All the types of real racing use shaft drive not belt....
.......THE TC3 WINS !!! PERIOD !!!
#36
http://www.rctech.net/forum/12769945-post4880.html
Please pay your attention on the innovations that will come with Awesomatix A700 Evo car to the end of this year.
#38
Tyres and straight line performance still have the biggest influence on lap times.
#39
if you go back to the beginning post i had planned on a discussion of that sorts, but it never got to that point, really once you get a set up for a track, like i am running my tc 6.1(not worlds) and i was running a. bear's from petite rc i think, and the only thing i changed was the rear droop, and really the rest was me fine tuning my car, and driving style, fastest car at our track until i hit the wall hahaha, but that will change, and really tires should be the first thing you pick out, this isnt offroad dirt were running on here, see what the others guys are running we are running jako blues or 32's and we seem to be fairly good, no one was too stuck
#41
Oleg, I did read the thread topic and to specially answer the question your car is the really only different option out there.
But tyres and power output are the two biggest factors in getting you 90% of the way to being fast. The chassi only contributes about 10% and they have all pretty much evolved to be very good.
Bert, I am a big fan of the TC3-4 ran the TC4 for years and they were very competitive against newer cars.
As good as newer cars no, why? Because mainance was a pain, too heavy and the design isn't quite as good.
IMO it is still the longest running car to remain competitive at local tracks.
IMO the future of RC cars if we stick with rubber tyres is better shocks (current shocks high frequency dampening sucks). Awesomatix is certainly a step forward, ultra low CG suspension but locally they haven't taken off.
#42
How about dampers with a spring inside the cylinder?
The current oil filled dampers rely on oil thickness and resistance through the holes in the pistons for dampening. And the rebound is set with ... It's hard to do different rebound accurately.
But if we had springs with different rates or/and lengths pushing the piston upward, setting the rebound would be a breeze. See my draft below.
Also the compression from full droop would be quicker which will translate to faster weight transfer front to back if desired. Or side to side without the use of excessively thick swaybars. Overall it will be another way to tune the shocks and suspension.
#43
#44
But tyres and power output are the two biggest factors in getting you 90% of the way to being fast. The chassi only contributes about 10% and they have all pretty much evolved to be very good.......
IMO the future of RC cars if we stick with rubber tyres is better shocks (current shocks high frequency dampening sucks).....
I have just remembered that I have tried this at 2002 TC Euro Champ in Lostallo and even finished some hits with still inflated tires.
Some benefits are obvious: less weight and possibility of the inner pressure adjustment.
Of course it needs a completely new design for the tires structure for better result but this is possible even for current tires.
#45
so it seems that the xray t4 has been winning a good amount lately, so what ever they are doing must be doing right, although id like to see it go up against the new 6.2 it would definitely be interesting, assuming both drivers are =
