Old 11-25-2013, 08:51 PM   #16
Suspended
I think you can easily go to 30 timing on the motor.... If you already have the spool,you'll need the losi lcd drives...You'll also need to Check your rear diff for slippage: if you hold the spur gear and One tire, you should not be able to spin the other tire easily... After that, it's boost time....
bertrandsv87 is offline   Reply With Quote
Old 11-26-2013, 04:34 AM   #17
Thanks for all the info guys. If I turn up the timing on the motor, is that the same as tuning the speedo if I'm going to put the timing back where it was once I start tuning the esc or no?
kmc978 is offline   Reply With Quote
Old 11-26-2013, 04:36 AM   #18
Ok so if I hold the tire and spur and turn the other wheel, it should turn but feel tight right?
Old 11-26-2013, 04:46 AM   #19
Nevermind, just checked the rear and it's damn tight. Can't even hardly move the other wheel.
Old 11-26-2013, 07:16 AM   #20
Originally Posted by kmc978 View Post
Searched the losi part # on towerhobbies site and nothing came up. What's a double cardant joint?
here is a link to a boosted setup
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
the losi part number for the LCD will be found on Horizon Hobby, but has been discontinued
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 11-26-2013, 07:46 AM   #21
Ahhhh ok I see them. Looks like slightly shorter cvd arms with those couplings. When you say "boost", is that the same as advancing the timing or is that in addition to/different?
Old 11-26-2013, 08:15 AM   #22
"boost" is essentially adding electrical timing in conjunction with mechanical motor timing at a set motor rpm. An electrical super charger of sorts is the easiest way for me to describe it.
Old 11-26-2013, 09:45 AM   #23
Pretty cool stuff. Someone earlier mentioned if I boost it, to lower the timing back down ok the motor. ???
Old 11-26-2013, 06:34 PM   #24
Hey 303slowdown, if I boost thru the esc, I should move the motor timing back down to where it was? Is there any way to do both safely or is it counterproductive?
Old 11-26-2013, 06:56 PM   #25
Trader Rating: 27 (100%+)
Are you just doing speed runs or are you racing?
You shouldn't have to worry too much about the motor temps. I'd be more worried about that RSPro on a 5.5 boosted motor. That sucker is gonna get hot very quickly. It's one of the reasons almost nobody runs boosted RS pros in the modified class. They just can't handle lower turn boosted motors.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 11-26-2013, 07:17 PM   #26
Hmmm. So u think the motor will be fine but the esc will fry?
Old 11-26-2013, 07:18 PM   #27
What if I just advance the timing on the motor? What effect will that have on the esc and motor?
Old 11-26-2013, 07:22 PM   #28
And all I do is street/parking lot runs. No organized racing. I guess it's more of just a drag car that I'm looking to get as fast as I can.
