Old 11-25-2013, 05:28 AM   #1
Default 235mm pan car questions
Does anyone know if a company makes a conversion kit for the rc10r5?
Also is there a big difference in performance in going to 235mm with this car or any pan car? what are the benifits of a wider car?
off the shelf, who make a 235mm?
MOTORCITY is offline   Reply With Quote
Old 11-25-2013, 10:44 AM   #2
Try Glen Nilsen at [email protected]
Don't know if he stills sells the conversion kits. Send him an email.
RoyU is offline   Reply With Quote
Old 11-25-2013, 07:44 PM   #3
"full option" makes a kit for that conversion
hutcholdschool is offline   Reply With Quote
Old 02-03-2014, 04:12 PM   #4
doublecut's Avatar
Default Full-Option 235mm comparison...
Hey, take a look at my post, it's from a couple of years ago but I was very competitive back then with this conversion:
http://www.rc10talk.com/viewtopic.php?f=37&t=26437
Good luck!
~R
doublecut is offline   Reply With Quote
Old 02-03-2014, 07:28 PM   #5
avs
avs's Avatar
Tony Shimko
avs is offline   Reply With Quote
Old 02-04-2014, 12:30 AM   #6
Good luck!
~R
Did you ever finish producing the upper pod plate to convert to a 10l2.5 with the wide pod?
If you did, do you have any left? I would like to get one 1 or 2
Old 02-04-2014, 06:05 AM   #7
howardcano's Avatar
Trader Rating: 35 (100%+)
The wider car will corner faster and be less twitchy, especially on high-grip tracks (like indoor carpet with a good groove). If grip is very high the wider car can corner faster before it rolls over.
On high-speed tracks, the wider car can generate more downforce, which again makes it corner faster.
But, as with many other things, the driver is more important to the lap times than the width of the car.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-04-2014, 12:26 PM   #8
doublecut's Avatar
Default Upper pod plate - 10L2.5
Unfortunately no, right in the middle of the designs I lost computer access, and the the company went out of business. I still have the files, but I need the correct program to continue the work.
I was thinking of purchasing a Autocad license this year and restart the project again.
I'll start posting again if this happens...
~R
[IMG][/IMG]
Originally, this design was intended to use CRC damper tubes, but now that Associated has both a 12th & 10th scale kits with damper tubes, the redesign with accommodate Associated parts exclusively.
~R
