Old 07-09-2005, 12:10 PM   #1
polesitter61's Avatar
Default Question about cooling fans
Do most of you use your fans to blow cool air on the motor or do they pull air away from the motor, meaning the don't blow on the motor they blow the opposite direction.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 07-09-2005, 12:25 PM   #2
Suspended
blow on to the motor
Inside a computer case, there's enough negative pressure to do it the other way around. But in RC application, there's not enough negative pressure.
403forbidden is offline   Reply With Quote
Old 07-09-2005, 12:28 PM   #3
Well then that brings another question, the Associated dual fans I purchased are blowing the wrong way then. I can't just turn them over because that would pinch the power wires that run into the fans between the fans and the mount. Could I switch the wires in the servo plug to reverse them, I have a spektrum reciever?
www.slickzero.com
Old 07-09-2005, 12:46 PM   #4
Eric Gebhard's Avatar
No, you cannot wire them in backwards to have them run the other way. The fans use brushless motors and the control circuit in the fan will not function properly. In fact you might even destroy the fan.
Eric Gebhard is offline   Reply With Quote
Old 07-09-2005, 01:54 PM   #5
ChadCapece's Avatar
Use servo tape to mount them. What you can do with the wires is put a strip of tape from outer edge of fan 1 and make it go accross that base and accross fan 2 base to the outer edge. Then cut out a small gap in the tape so you can run the wires. This will make the wires sit below the fans, but not being pinched by the chassis plate and the fan base. This is assuming your running the fans beside each other like this {}{}
ChadCapece is offline   Reply With Quote
Old 07-09-2005, 02:35 PM   #6
u can buy the "muchmore" fan , that is very enough pressure to blow cool air on the motor
rayspeed-SD is offline   Reply With Quote
Old 07-09-2005, 03:44 PM   #7
Thanks for all the suggestions guys, I ended up laying a thin bead of black silicone all the way around the mounting surface of the fans and setting them in place. After the silicone set up I put some maching screws and nuts to hold them down. Good suggestion with the tape too, I just have a hard time holding everything on these "luxury" touring cars with double sided tape! LOL!
www.slickzero.com
Old 07-09-2005, 04:12 PM   #8
I have a question, do you use a 25mm or 30mm fan for the motors?
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 07-09-2005, 04:30 PM   #9
I bought a mount from team tamale (spell?), it used the Associated fans they are indeed a 25mm fan. Here's some pics.
www.slickzero.com
Old 07-10-2005, 07:35 AM   #10
jdm19turn's Avatar
nice pics iam looking into getting a fan for my xray fk05 also does anybody know what's the best fan to go with and what size. i won't to run a single fan setup.
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 07-10-2005, 09:52 AM   #11
ChadCapece's Avatar
Sup joey, this setup would be the cheapiest and probably the most efficient for 19turn. http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
Here's the air scoop I told you about: http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1 I really can't use them on my LCG, b/c the RX sticks out too far. I'll give you one for free if ya want to try one out. It weighs almost nothing and is clear.
Old 07-10-2005, 12:21 PM   #12
I just ordered on of these double fans from Cool Can Fans. I saw some at the Reedy Race and they looked really well made.
http://search.ebay.com/cool-can-fans_W0QQfkrZ1QQfromZR8
pops is offline   Reply With Quote
Old 07-11-2005, 12:26 PM   #13
J-P
J-P's Avatar
Hi,
if anyone is interested in one of the cool can fans or would like any infomation about them, pm me and i will give you a price shipped to the USA and answer any questions.
J-P
J-P is offline   Reply With Quote
Old 07-11-2005, 01:14 PM   #14
ChadCapece's Avatar
Originally Posted by J-P
Hi,
J-P
edit
Old 07-11-2005, 01:18 PM   #15
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Shoot how much for just the two fan mount for the LCG I have fans?
Also a two fan mount for the BD...I still have fans...
Thanks,
-Shookie <><
Originally Posted by Pro4Capece
edit
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Cooling fans for EP On Road DOON!!!! Australian Racing 4 03-28-2007 04:27 PM
ARE COOLING FANS WORTH IT? gonzo416 Electric On-Road 41 02-03-2007 06:12 PM
Motor Cooling Fans..... RED-LINE M03 Florida Racing 2 06-25-2006 10:02 AM
Cooling fans RKeasler Electric On-Road 8 09-18-2005 03:13 PM
Cooling fans BillyCaldwell Electric On-Road 11 07-01-2005 07:54 AM
