Old 03-17-2014, 09:48 PM   #16
Schs2013's Avatar
nice pictures and videos.
VBC Lightning 10LM 21.5, WCICS spec M05v2, VBC D07 21.5 USGT
Schs2013 is offline   Reply With Quote
Old 03-18-2014, 08:09 AM   #17
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Thanx! car is for sale now 150 for the roller with a Tekin 21.5!
MantisWorx is offline   Reply With Quote
Old 04-14-2014, 10:18 AM   #18
Hi, you did a great job on this car. I have the same one and have been looking for a different spur gear. You stated, you made your own adapter. Could you maybe point me in the right direction for what you purchased to make it work?
The plastic spur needs to go, it's the last week point of the car!
Any guidance would be appreciated!
Thanks,
Chris
ploshayc is offline   Reply With Quote
Old 04-14-2014, 11:03 AM   #19
MantisWorx's Avatar
Thanks,
Chris
Unfortunately i custom made it and only made 1, the class died here locally so i no longer run the car or the class. Car is still for sale though
Old 05-16-2015, 01:44 PM   #20
Crash13's Avatar
Default slightly modded v100
added a few options as well as a 38t pinion and a 60t spur to run with the 21.5 motor. Motor manufacturer suggested a 3.5 overall ratio, it is now about 3.8.
aluminum driveshaft and drive ends, optional camber arms, aluminum motor mount, cva shafts and some plastic shocks from a Ofna JL10E?
Plan to run it in our outdoor summer series
Project Vaterra V100-C USGT/VTA-image.jpg
say no to LH turns only
Crash13 is offline   Reply With Quote
Old 05-16-2015, 02:15 PM   #21
Crash13's Avatar
Default body
for some reason can not upload more than one image with the iPad
Old 02-29-2016, 08:33 AM   #22
Default Vaterra V100 body options
Can I run a 190mm body on my Vaterra V100? I have seen a lot of people switch bodies and mostly people are running a 200mm body but I don't like the hang over on the fenders.
jbrook75 is offline   Reply With Quote
