Old 07-09-2005, 10:57 PM   #16
AdrianM's Avatar
I have seen guys dump their cells to 5.4v then dead short right away. They get really hot and I don't think its good idea but if you tray your cells before shorting, the lights are out and the pack is at room temp then you are certainly safe to short.
Adrian Martinez
Old 07-10-2005, 08:55 AM   #17
TeamPink91's Avatar
Send a message via AIM to TeamPink91
I'm a hardcore deadshorter, and like adrian said, it is so important to make sure the pack has been on the tray for a while and until it cools off to room temperature.
TeamPink91 is offline   Reply With Quote
Old 07-11-2005, 07:03 AM   #18
AdrianM's Avatar
Originally Posted by raving-monkey
do you mean charge your batts normally..when they finish charging, leave them for 1 minute and then repeak?
I use a Turbo 35BL so I set a normal charged as described with a 60 sec delay and an auto repeak as described.
Adrian Martinez
Old 07-12-2005, 05:33 AM   #19
Hey Hyper1, I use a ten dollar voltmeter from radio shack thats worked great for years, so If your built in one from your turbo charger acts funny, Im not sure I would trust it.....and if you have a pack thats been shorted for a week as you mention, It could rebound very slowly (or not much at all) and be just fine, It dosn't nesesarily mean a cell is reversed....but you can easily tell when you charge it (also with a voltmeter )......personally,Im not sure that I'd risk deadshorting a pack configured as a stickpack.....bringing a stickpack to true zero volts runs a higher risk of reversing one or more of the cells since your not bringing each cell down independently.....if this is something really important to you with those packs, I'd just re-solder them to side by side configuration and trey the cells individually.....good luck
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 07-12-2005, 05:46 AM   #20
KREATOR1's Avatar
Send a message via Yahoo to KREATOR1
what do you do when your batt has no punch and dump in modify class?
Do i need to cycle? how many time should i do it?
TA04ss / TA04TRF / TB EvoIII/ TB02 /DF02 / M03L / TRF414m2 / TRF415 / TRF415MS / TRF415MSX / MRE
KREATOR1 is offline   Reply With Quote
Old 07-12-2005, 01:29 PM   #21
Did you used to make runtime with the battery your talking about? if so, was it with the same mod motor and gearing combo that you can't make runtime with now?......Im Just asking because there's obviously quite a few variables to what your asking.....In my experience, cycling a NIMH pack will usually only wake the pack up if it's bran new or has been sitting for a while.... you could always cycle the pack to see what it's exact numbers are (if your charger gives you that info) this way you can see if your battery is dropping off from it's lables or if the problem lies elsewhere (like your gearing or your speedcontrol drive frequency being too low)..........Joe
cycling? Mitchell Rookie Zone 9 05-06-2007 04:32 AM
Battery cycling question HarshGuy Electric On-Road 56 08-16-2005 01:25 PM
Battery Cycling? Nrctc3 Rookie Zone 0 02-06-2005 02:13 PM
battery cycling treble Australian Racing 2 10-03-2003 05:16 AM
