Old 11-19-2013, 02:02 PM   #1
Send a message via MSN to Mogg Send a message via Skype™ to Mogg
Default Carpet set up for trf451msxx
Can any one help with a base set up for carpet running rubber 28 JB tyres as was racing out side on tarmac (ash felt) now looking to use the car on carpet as have to many spare parts for it.
www.ydmrcc.com
Mogg is offline   Reply With Quote
Old 11-20-2013, 02:36 PM   #2
Please.
www.ydmrcc.com
Old 11-20-2013, 03:44 PM   #3
I will dig out one of mine tonight.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 11-20-2013, 05:38 PM   #4
EDWARD2003's Avatar
http://www.rctech.net/forum/electric...rf415-693.html
Click the link above and scroll down a little. I used this Martin Crisp setup on my 415msxx and it would like a charm.
EDWARD2003 is offline   Reply With Quote
Old 11-24-2013, 04:35 PM   #5
That one is for foam and in the U.K. we have to run rubber on on T.C. any one got a rubber set up please?
But I'll give it a go but I'm running lipo and brusles motor so don't no if it will work with that?
www.ydmrcc.com
Old 11-25-2013, 12:32 AM   #6
EDWARD2003's Avatar
This setup works well for any motor.
Here's a setup that will work for carpet.
Front
springs : tam white
swaybar : yellow (white if you want to reduce steering)
upper links : 3mm spacers under inside link
camber : -1
toe : 0
caster : 4 degree block
Kickup : none
UpTravel/droop : 3mm
rideheight : 5mm
one way : yes
Shock positions : outer holes top and bottom.
Tire : CS22 with medium insert - full compound. (less if you want to reduce steering)
Rear
springs : tam blue
swaybar : yellow
upper links : 0mm spacers under inside link
camber : -2
toe in : 2.0 to 2.5 depending on grip level and condition of tires
Antisquat : none
UpTravel/droop : 1.5 to 2 mm
rideheight : 5mm
