Old 07-07-2005, 07:46 AM   #1
Default Drifting tires?
Which tires are good for drifting?
AZNracerx1989 is offline   Reply With Quote
Old 07-07-2005, 07:48 AM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
PVC pipe works best plus mine have lasted forever...and they are cheap...just take a rim with you to Home Depot or Lowes and find the right size caus emy head hurts and I forgot the size...LOL...these would be just for fun...but for serious racing you would have to ask someone who races drift cars.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 07-07-2005, 07:49 AM   #3
lol... thats too slipperyhahaha
Old 07-07-2005, 07:52 AM   #4
does pvc pipe actually run... or does it just burn out
Old 07-07-2005, 10:08 AM   #5
TeamPink91's Avatar
Send a message via AIM to TeamPink91
Surprisingly it actually goes pretty well with pvc. Me and my friend just take the bare wheels that come with Xrays and slap them on and jack up the ride height.
TeamPink91 is offline   Reply With Quote
Old 07-07-2005, 11:18 AM   #6
I run PVC when running on rutty parkinglots and run old rubber tires with electrical tape wrapped around them on smooth surfaces. The electrical tape tires give a more realistic drift while the PVC tires are just crazy because of the stuff you can do with them (going backwards while the wheels are spinning forward, 50*+ drifts..)
smojoe is offline   Reply With Quote
Old 07-07-2005, 11:38 AM   #7
ChadCapece's Avatar
They hook up fine. I've run them with a mod motor and 3600's. You can just sit and do donuts until the battery runs out. But you can get forward traction and make your car steer. I've ran about 10 packs with my tires, and they still work fine. I bought my PVC tires off ebay cause I'm too lazy to go to Lowes
ChadCapece is offline   Reply With Quote
Old 07-07-2005, 11:52 AM   #8
Plus if you have a good dremel you can cut grooves into the PVC to add a tiny bit of traction...kind of like the old dirt oval and there foam tires...LOL
-Shookie <><
Old 07-07-2005, 11:59 AM   #9
axel's Avatar
when i was into drifting i used ABS pipes i prefered it over PVC because it was black. When drifting it's all about making your car look real as possible.
axel is offline   Reply With Quote
Old 07-07-2005, 01:58 PM   #10
ChadCapece's Avatar
Uhhhh, my bad, I was using the ABS. I called them PVC, but they were black Sorry about that, but I'm sure they work just as good as the PVC.
Shookie, grooves would help the pick-up alot. Good idea
Old 07-07-2005, 02:23 PM   #11
do you put hte pvc around your rims or around your tires
Old 07-07-2005, 03:14 PM   #12
rc_bam226's Avatar
Put the PVC or ABS tires around the rims. Use some electrical or duct tape and put it on the wheel before you "slide" on the tire. This helps keep the tire on the rim, or else they will slide off the rim as you drift.
rc_bam226 is offline   Reply With Quote
Old 07-07-2005, 05:42 PM   #13
JamieDexter's Avatar
I never liked PVC, too un-realistic and hard to chain drifts, I use electrical tape or clear hockey tape. Gives good speed, easy to handle and realistic drifts
JamieDexter is offline   Reply With Quote
Old 07-07-2005, 11:33 PM   #14
I use some Black ABS pipe from home depot for just only 1.50 for a 4ft pipe, then use a good old hack saw and a vise to hole the pipe and cut away slabs of abs tires. I run my TC4 with a speed Gem Extreme 17T mod motor and at first you kinda have to break in the tires you know scratch them up while drivin-Drifting hard and there you should have some pretty good runs and a heck of alot of freaken fun.
Rickster2005 is offline   Reply With Quote
Old 07-07-2005, 11:40 PM   #15
Entropy's Avatar
Check out some vids of PVC drifting that my buds and I did sometime back.
http://www.frequency-rc.com/portal/h...nChannel=Files
I know this is old, but some guys may have just started drifting and this will be an inspiration that you can do anything with PVC piples...
Entropy is offline   Reply With Quote
Drifting Tires: Buy or Make? kang45 Rookie Zone 11 12-04-2007 05:37 AM
drifting help mr ektid Canadian R/C Scene 3 09-03-2007 03:09 PM
drifting with pvc pipe or yokomo zero one tires? zisman Nitro On-Road 0 08-06-2007 09:46 AM
Sooo what kinnd of tires for drifting do you perfer? samcook90 Electric On-Road 4 12-08-2006 07:59 AM
Drifting! KevanB Electric On-Road 43 11-22-2004 11:02 AM
