Old 07-06-2005, 02:10 PM   #1
Default why is my xray fk05 a heap
my tamaya is much better than my new xray it is very slow and i use a 7 turn motor in the stock and i still am getting hammered on the straight
spottyscotty is offline   Reply With Quote
Old 07-06-2005, 03:30 PM   #2
there are many different factors to why your car might not be as fast at the other cars.....not just a motor...
HEWITT is offline   Reply With Quote
Old 07-06-2005, 05:48 PM   #3
dmatter's Avatar
Maybe it's A$$ is Dragging
dmatter is offline   Reply With Quote
Old 07-06-2005, 05:51 PM   #4
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Your getting outrun on the straights by stock motors and your running a 7 Turn?????
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 07-06-2005, 06:05 PM   #5
dmatter's Avatar
Old 07-06-2005, 06:06 PM   #6
dmatter's Avatar
tamaya
Old 07-06-2005, 06:18 PM   #7
N4S
N4S's Avatar
The internal gear ratio of the two cars are different..... You cant run the same pinion and spur on both cars and get the same final drive. Get yourself a gear chart and find the final drive of your tamiya with your current pinion and spur. then get a pinion and spur combo for the xray that is the same or close to it.
N4S is offline   Reply With Quote
Old 07-06-2005, 06:29 PM   #8
jw92656's Avatar
Smile
Your internal drive ratio is different in both cars. Tamiya's is 2.54, and XRAY's is 1.77.
Here is the formula to figure out. Spur / pinion x internal drive = final drive
Example: Tamiya 102/37*2.54= 7.00
Example: XRAY 102/37*= 4.88 (Big difference..)
Also don't try to convert the pitch, as it will limit what ratios you can run.
Keep Tamiya at 64 pitch, and Xray at 48 pitch.
I own a Xray FK04, and a Tamiya 415MS. Trust me the Xray is a missle, and should be outshining your Tamiya, especially in cornering.
I think the FK 05 has to have the diff repacked with some lube and the rings polished up a little. Check on this though I believe it's what I have read some owners are having to do.
I hope this might help :-)
jw92656 is offline   Reply With Quote
Old 07-06-2005, 06:31 PM   #9
To clearify things, the internal gear ratio is 1.70 for FK05.
skinart76 is offline   Reply With Quote
Old 07-06-2005, 06:43 PM   #10
just go here to get a gear chart ..,, www.gearchart.com ...!!!!
7 turn getting whooped by a stock motor ???? yeah right ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 07-06-2005, 07:00 PM   #11
Trader Rating: 29 (100%+)
yeah...those things are way to slow.....ummm wanna sell it cheap....
honestly you just have something wrong, once you get it figured out, it will be just as fast as any other car.....
Mdoc is offline   Reply With Quote
Old 07-06-2005, 07:03 PM   #12
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
ahhh which tamaya tlo1.... hahahahahaha either you are exaggerating the truth Pinocchio... Or Gepetto has not the skill to set up a new xray
still fishing
ALBERTO is offline   Reply With Quote
Old 07-06-2005, 07:09 PM   #13
NVisible's Avatar
send me your fk05, ill get it working for you
NVisible is offline   Reply With Quote
Old 07-06-2005, 07:57 PM   #14
raving-monkey's Avatar
Send a message via MSN to raving-monkey
note - he never said he would send it back
only joking NVisible....we all trust you really
raving-monkey is offline   Reply With Quote
Old 07-06-2005, 08:25 PM   #15
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I guess its also possible you're not getting full throttle..
Set your throttle trims to 0 and re-program your ESC inputs for full throttle and full brake.
v0rtex is offline   Reply With Quote
Heap of R/C gear for sale CHROME MAD Australia For Sale/Trade 4 08-03-2008 02:19 AM
JRX-S with a heap of spares and body rcstunt101 Australia For Sale/Trade 12 07-10-2007 09:23 AM
GPX-4 Pro Chassis with heap of extras $470 murf37 Australia For Sale/Trade 2 07-09-2006 04:53 AM
Xray FK05 kylehirano R/C Items: Wanted to Buy 3 09-13-2005 02:31 PM
