Old 10-30-2013, 04:41 PM   #1
Default camber gauge suggestions
I'm in need of a good camber measuring device for setting up my drift chassis. Any recommendations for good and reasonably priced gauges? Not looking for the cheapest, but don't want to spend top dollar either. Just need something of good quality that'll let me dial in my camber adjustments properly and isn't cheap plastic that'll break.
wareagle84 is offline   Reply With Quote
Old 10-30-2013, 04:46 PM   #2
Send a message via ICQ to JiuHaWong
Integy?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 10-30-2013, 06:12 PM   #3
Regional Moderator
CarbonJoe's Avatar
Hard to beat the RPM camber gauge. It's plastic, but nearly indestructible.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-30-2013, 08:15 PM   #4
ThePanda's Avatar
Trader Rating: 65 (100%+)
^and its cheap!
ThePanda is offline   Reply With Quote
Old 10-30-2013, 10:30 PM   #5
VenturaDC's Avatar
Trader Rating: 32 (100%+)
+1
Whenever I don't use my full setup station that's the gauge I grab.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 10-31-2013, 04:20 AM   #6
cool I'll check out the RPM and Integy.
thanks guys.
