Old 07-02-2005, 06:20 PM   #1
Send a message via AIM to odawg315
Default amp draw?
exuse me if i sound ignorant, im just starting to try and figure out motors so i started on a stock trinity. i have an ice charger and it has a break in cycle on it, when i do this at 5 volts witch was recomended to me does anyone know what kind of amp draw i should be doing @ 5v.
odawg315 is offline   Reply With Quote
Old 07-02-2005, 06:24 PM   #2
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
When I break in my motor it is for 1minute @1V or if you like 2V....
With a really good stock motor @ 1V it should be 4.5amp & @2V more like 8amp
This would be a very good motor and one that I would be comfortable racing.
But I ahve had motors that only get 3.5amp @1V and they still rip...
really drive each motor and compair lap times...Some motors are better for another track than others...
each motor is not created equaly.
Just from what I've found..
Hoep this helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 07-02-2005, 06:32 PM   #3
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
When running your motor to break it in or seat the brushes, common practice is 3 volts for 200 seconds.
As for amp draw, many things factor in for amp draw.
A motor (stocker) that pulls high amp draw could either be a motor with a good amount of torque, or has heavy brush spings, or is binding somewhere.
A motor that pulls a lower amp draw could have a good amount of rpm, lighter springs or is just a flat out worthless motor.
Expierement with changing different tension brush springs and that will give you an idea of what it does to amp draw, also drive these motors so you can see what it does to the "on track" characteristics.
1armed1 is offline   Reply With Quote
Old 07-02-2005, 06:56 PM   #4
well the first one i did, used prple springs, teflon washers, i polished the bushings, and using cross serrated brushes, it peaked at 8.02 [email protected] 3v, and peaked at 11.01 @ 5v. does this sound strong?
Old 07-02-2005, 08:39 PM   #5
Team EAM
EAMotorsports's Avatar
Send a message via AIM to EAMotorsports
Amp draw is the worst way in the world to determine if a motor is good or not. The higher the amp draw the higher the RPM usually.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-02-2005, 08:52 PM   #6
Hyperform Racing's Avatar
EA
Yup, no load amp draw is pretty useless...
Hyperform Racing
www.Hyperform-Racing.com
[email protected]
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 07-02-2005, 08:55 PM   #7
Send a message via AIM to BONZAIII Send a message via Yahoo to BONZAIII
Then for the guys who are now trying to figure out motors what is the correct way to break in a motor.I have been told 300 [email protected] volts and 4 volts.Everybody has different ways.I have been breaking them in for 300 secs at 2 volts.If checking a motor by amp draw is wrong then how do we check them?I use a CE turbo 35BL is there a way to check the motor out on it?
BONZAIII is offline   Reply With Quote
Old 07-02-2005, 08:58 PM   #8
It depends on the brushes. I run them in at 2 volts until fully seated. For example, 767s usually take a couple minutes where f-brushes can take 5 or more minutes
Hyperform Racing
[email protected]
(978) 416-2572
Old 07-02-2005, 09:00 PM   #9
What kind of equipment do we need to properly check a motor to see what it is doing?
Old 07-02-2005, 09:01 PM   #10
A dyno, pref a turbodyno...
Hyperform Racing
[email protected]
(978) 416-2572
Old 07-02-2005, 09:03 PM   #11
Who makes it and how much are they?
Old 07-02-2005, 09:06 PM   #12
you can only get them used on ebay or similar places these days. they were made by competition electronics. they go for around $750 or so. ce did make 50 this year but there was a waiting list, they went mostly to tuners and I heard they were $1500.
Hyperform Racing
[email protected]
(978) 416-2572
Old 07-02-2005, 09:11 PM   #13
Team EAM
The best dyno in the world is the track and a stop watch.... 2nd best is a Turbo dyno.
Hyperform is correct on breaking in brushes. I do all mine at 2 volts with a small fan. Usually 300 seconds for 767's and 500 seconds for F brushes.
EA
Contact Us
Old 07-02-2005, 09:12 PM   #14
I appreciate the help but for some people I included do not really have the money to purchase this type of equipment.I put more money in my car keeping it as competitive as I can.With all that said is there an alternative for someone like me to test a motor besides running it to check it and possibly determine if the motor is worth racing or demoting it to a practice motor?
Old 07-02-2005, 09:18 PM   #15
EA
True that EA... The majority of the time, we find a motor that runs really well on the track and then dyno it to record it's characteristics.
Hyperform Racing
[email protected]
(978) 416-2572
amp draw mizeracing Radio and Electronics 3 08-27-2008 08:18 PM
motor amp draw Z-Fire Electric On-Road 0 05-04-2008 05:18 AM
Amp Draw Jake S Electric On-Road 37 09-09-2007 03:11 AM
Amp draw blatman Australian Racing 12 06-30-2005 08:16 PM
Amp Draw formula... vito c. Electric On-Road 2 03-09-2005 11:23 PM
