Old 10-22-2013, 08:17 PM   #1
Default 1/12 diff grease what do you use
hey im rebuilding my diff and not sure what to use/ whats the best?
anti wear grease
white auto
red high temp auto bearing
tamiya diff
or what
thanks
TeamThibault is offline   Reply With Quote
Old 10-22-2013, 08:27 PM   #2
DesertRat's Avatar
The very best Team Associated clear silicone ball diff grease. If you buy an Associated offroad vehicle once a decade as I do, you have enough grease in that kit to race 1/12 pretty much continuously.
Don't use black grease, real-car grease, lithium grease, or moly grease as they are too slippery. Ball diff grease cant be super-lube as the ball still needs some 'bite' on the ring. Black grease is great for a lot of stuff in a 1/12 scale, like thrust bearings, just not this.
I hope that helps a bit.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-22-2013, 09:24 PM   #3
Car Breaker's Avatar
I use Schumacher ball diff silicon grease and like it a lot. A friend of mine use 300k diff oil on the balls as diff grease. So much cheaper and run great
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 10-22-2013, 09:52 PM   #4
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
AE 6636
Lock Topic
Old 10-23-2013, 01:10 AM   #5
Trader Rating: 60 (100%+)
Why 6636 and not 6591?
PROMODVETTE is offline   Reply With Quote
Old 10-23-2013, 11:12 AM   #6
Associated, Losi, Tamiya ball diff grease are the best I've used.
A tube of each lasts for many, many rebuilds. This is one area where cheap will cost more.
AreCee is offline   Reply With Quote
Old 10-23-2013, 12:03 PM   #7
masterhit's Avatar
Trader Rating: 15 (100%+)
Josh Cyruls take on diff building.
CRCs take on diff building.
These seem to back up what I have always heard about the stealth lube being too "slippy".
Works for me!
Mike Slaughter
masterhit is offline   Reply With Quote
Old 10-23-2013, 03:06 PM   #8
Radio Active's Avatar
Tamiya Ball Diff Grease is the only one I won't use. It's far too gritty.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 10-23-2013, 04:51 PM   #9
AE grease (the regular stuff and not the stealth stuff) and only AE grease. Nothing else that I've tried works nearly as good as the AE stuff. One little tube will last for years and years.
vafactor is offline   Reply With Quote
Old 10-24-2013, 05:07 AM   #10
Yeah AE grease for me, works great.
PurcyP is offline   Reply With Quote
Old 10-24-2013, 07:28 AM   #11
AE red label grease...
JamesL_71 is offline   Reply With Quote
Old 10-24-2013, 11:47 AM   #12
racer x 1's Avatar
Trader Rating: 27 (100%+)
I prefer to use the kyosho stuff. Not sure on the part number or if its available seperately but it came in my rb6 and man its awesome! If not that the standard issue associated stuff works a treat.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-24-2013, 01:34 PM   #13
JayL's Avatar
red label, 6636 is silicone
it works best
I keep going back and forth between 6636 and schui, can't decide if one is better.
MOD: A800X LRP FlowX X22 4.5T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 10-24-2013, 02:44 PM   #14
All good advice to be followed - AE diff grease for me too.
All the lube needs to do is lubricate the balls against the plastic of the diff gear. This is the only part of the diff where friction will affect the diff action. All the drive from the motor to the axle is taken through the balls. The spur gear pulls the balls around, so when you turn there is a lot of force between the balls and one side of the holes in the spur gear.
Like Josh says, ceramic diff balls and a Kimbrough spur gear are an absolute must for a good and long-lasting diff build. Machined spurs are hopeless as during racing when the car turns, the spur 'falls off' the crown of the balls as they turn and collides with the face of the diff plates giving all sorts of unwanted friction in the diff. HTH
SlowerOne is offline   Reply With Quote
Old 10-24-2013, 08:30 PM   #15
Ya, the AE grease is good. The best part is after you build few AE cars, you will have all the grease you need for the rest of your life. LOL
www.beamcat.com
beamcat is offline   Reply With Quote
