Old 10-23-2013, 10:08 AM   #16
mac853's Avatar
Originally Posted by ThePanda View Post
Never used that, i have used the pargon stuff though
you mean fxii?
mac853 is offline   Reply With Quote
Old 10-23-2013, 10:27 AM   #17
ThePanda's Avatar
Trader Rating: 65 (100%+)
Originally Posted by mac853 View Post
you mean fxii?
Yes that is it.
ThePanda is offline   Reply With Quote
Old 10-23-2013, 10:30 AM   #18
mac853's Avatar
Talking
Yes that is it.
Thanks!
Old 10-23-2013, 06:50 PM   #19
Suspended
I would not go with the softest springs you can find. You need to consider the type of bumps, are they rises above the normal or are they divots below the normal. When i look at the surface I see a lot of divots where the grout is between the bricks, so, you want a fair amount of rebound and rear droop and low pack in the shocks to keep the tires on the surface as you go over the grout lines, with a fairly high ride height 7mm ish to allow the car to roll. Over all, it is going to be a pig of a surface to get a good setup on, and one to find much traction on. I wish you luck.
RogerDaShrubber is offline   Reply With Quote
Old 10-23-2013, 08:57 PM   #20
ThePanda's Avatar
Get a spring set, that way you can experiment with what wold work best. Some companies offer different sets, for example tamiya offers ha hard, and a soft spring pack, if you have the option, get the soft set.
Old 10-24-2013, 11:00 AM   #21
mac853's Avatar
Cool
I have prepared to using Tamiya red and yellow springs on my old Cyclone TC for this race.
Old 10-24-2013, 08:35 PM   #22
If just rubber tires use buggy grip. Apply it the night before and put it in a zip lock bag overnight. Pargon stuff donot work well on these kind of surface.......
www.beamcat.com
beamcat is offline   Reply With Quote
Old 10-25-2013, 06:43 AM   #23
mac853's Avatar
Are you from HK, what do you think about these Speedmind roadfighter radials, could use buggy grip 2?
In fact i have got that Mumeisha traction compound, could be acceptable?
If you don't mind please don't hesitate to share me your experience and some setup tips, please?
Best regards
Old 10-25-2013, 08:09 AM   #24
mac853's Avatar
I will measure the car height from my big diameter radial tires but not from setup station.
Spring is still doubt, maybe i will put the shocks standup with tamiya red rear and yellow front or hpi blue rear with silver front, but this depends layout, despite i have hear it could be not technical but so small that just could run 6 cars on same time.
