Another Tamiya shock question....
Originally Posted by onebeatuptc3
then what is the reason for giving you the black o-rings? is that to get the shock shaft the right length for use on other vehicles?
Btw: these shocks are going to on my xray, so does that make any difference?
Diffuser is right, the clear o-rings go into bottom of the shocks with the guides
I'm not sure about using them on an xray, I think there is a thread somewhere (P-Dub's, I think) that explains everything you need to mount them
Originally Posted by DZ
For xray's do not use the o-ring on the shaft to limit the length.
You need the full length of the shock to work on any of the xray T1 series
Cheers
DZ
Cheers
DZ
thanks for the help, i finally got everything worked out. I just wish the directions would have specified which o-ring is which, because all it says is O-ring. Its somewhat frustrating, but i understand it alot better now. I do have to say these shocks are really easy to build, alot easier then my xray shocks.
Also, just out of curiousity, is it alright to have some threads on the bottom of the shaft exposed? I needed to back the ball end off a little to get them to fit correctly and be to adjust them.
