Old 07-05-2005, 12:15 AM   #196
fai
Regional Moderator
fai's Avatar
Mars: Congratulation! I think you were completely exhausted at the final day...
I still feel sleepy now... zzzzz
fai is offline   Reply With Quote
Old 07-05-2005, 12:18 AM   #197
fai
Regional Moderator
fai's Avatar
See!
Old 07-05-2005, 01:18 AM   #198
Mars's Avatar
Yes I was.....but I still enjoy the race
Mars is offline   Reply With Quote
Old 07-05-2005, 01:45 AM   #199
Mars's Avatar
Some facts about the Invitational,
As can be seen from the pic of top 3, body of choice was Excel or Ride Accord. I was using a Stratus 3.0 carpet version initially and switched to the Excel as it provided much more stability
Wheels and inserts are not controlled. JB foam was the obvious choice for most racers. Many Japanese racers used Tamiya dish wheel. They said tamiya wheel provide more traction compared to say Yokomo wheels. I found this out too late
Many racers initially tested higher turn motors when the traction was not good. Finally most of the racers settled with 6 or 7 turn motors as far as I know. The fastest car was hara's cyclone. He was just ballistic down the straight!
KO's staff was at the race to help programming the VFS escs and repairing any burnt ones.
Top racers all used GP battery. Intellect are more popular among the locals.
Old 07-05-2005, 03:32 AM   #200
So hara was the fastet..?hmm...I think he was the only one running 6T motor , you need to be very smooth on the throttle even with 3700 cells to run such powerfull motors!
Do you have an idea of the FDR (ratio) they were using?
thx!
Tbevofreak is offline   Reply With Quote
Old 07-05-2005, 03:53 AM   #201
chaini's Avatar
Exclamation
Originally Posted by Black Adder
Are the fans coupled to the battery wires or put in to the reciver?
Can anyone confirm, that this was MASAMI'S CAR? Why he didn't use his own yellow MASAMI KO ESC?
chaini is offline   Reply With Quote
Old 07-05-2005, 03:54 AM   #202
chaini's Avatar
Originally Posted by Leini
many drivers use fans on the KO speedo! this is masamis BD with two of them...
Old 07-05-2005, 04:06 AM   #203
fai
Regional Moderator
fai's Avatar
Yes... I think it's the car he used on day2/3!? Please correct me if I'm wrong!
Old 07-05-2005, 04:38 AM   #204
fai
Regional Moderator
fai's Avatar
Mars, I also found that my TOP wheels work better than my Xenon... Cuz of the thickness of rim wall!?
Old 07-05-2005, 05:08 AM   #205
Mars's Avatar
thx!
Yes, Hara's car seems to have the most acceleration out of the corners and incredible top speed. Surikarn's and Masami's car have comparable top speed by not the same amount of acceleration. Masami was also running 6 turn. Not sure about his exact gear ratio, but it was something around 9.5.
Old 07-05-2005, 05:18 AM   #206
Mars's Avatar
Positive, that was Masami's car. His car had problem right before the last corner and made him finish second in his race 1. Not sure whether that was esc or motor problem. Perhaps KO guys replaced his esc with standard one.
Old 07-05-2005, 05:20 AM   #207
Mars's Avatar
Fai, probably due to wheel size. I haven't measure the size myself but other told me that Tamiya wheels are slightly smaller than Yokomo ones.
Old 07-05-2005, 06:32 AM   #208
Thanks for the comments Mars , Masami seems a little under-powered compared to Hara and Surikarn comming out of the last corner and onto the straight
Did Oscar have secret motor setup? I heard that there is a new Flat brush, any comments on this? I think its only for Factory Drivers at Big Races, maybe its a very short brush to help lowering resistance..?
cheers!
Old 07-05-2005, 07:18 AM   #209
Leini's Avatar
oscar has always some nice ideas....
Leini is offline   Reply With Quote
Old 07-05-2005, 07:35 AM   #210
hara & Surikarn used 6x1 motor , Oscar said only race 6 mins
HKRCMODEL is offline   Reply With Quote
Niko Cup...Grand Final...2007...Johor...Serpent Asia Nitro Tour 2008...Hong Kong 819 Malaysian R/C Racers 371 12-28-2007 09:16 PM
where to race in hong kong? pimplemaster Hong Kong Racing 1 04-16-2007 05:52 AM
Hong Kong Race Meetings LexLoafer Hong Kong Racing 5 11-26-2005 05:29 AM
Reedy Race Asia chaini Electric On-Road 0 06-28-2005 03:23 AM
reedy race of asia Kyew Singapore R/C Racers 16 09-10-2003 04:50 AM
