Old 06-27-2005, 09:11 PM   #1
Smile which one
Im geting two things which one should i get first a tire truer or a motor lathe thank u for reading this
Matthew.H is offline   Reply With Quote
Old 06-27-2005, 09:20 PM   #2
axel's Avatar
a comme lathe has been on my mind for a bit so comme lathe. But what do you think you would need more?
axel is offline   Reply With Quote
Old 06-27-2005, 09:32 PM   #3
tc3blue's Avatar
comm lathe first, i'd say. if camber is set up the right way the tires should be OK, they should wear pretty evenly, BUT if a comm really needs cut, you can't run your car anymore or it's be half as fast.
just my.02c............
tc3blue is offline   Reply With Quote
Old 06-27-2005, 11:43 PM   #4
loopedeloop's Avatar
You can cut tires on any lathe but you really want a comm lathe if you going to cut your armatures.
loopedeloop is offline   Reply With Quote
Old 06-28-2005, 02:05 AM   #5
axel's Avatar
comme lathe would be more useful cause it's inevitable that you will need to cut your comme than true your tires.
