Will there be a 1/10 McLaren P1? >
Old 10-09-2013, 02:56 PM
firefoxussr's Avatar
Default Will there be a 1/10 McLaren P1?
I would love to see it. I saw that Tamiya is releasing the LaFerrari. Haven't looked into the Porsche 918.
This leads me to another question- could someone feasibly use a 3D printer to create limited shells? Or maybe the 3d print is just used as a master mold. I suppose the print would have to be made of something that could stand the heat of a lexan sheet all heated up (youtubers do this).
Here's some other cars that would be awesome as bodies:
BMW M1*
Lancia Beta Montecarlo Turbo*
Maserati MC-12*
Ford RS200*
Zender Fact 4
Vector WX-8 Twin Turbo
Maserati Bora
Jaguar XJR-15
*one exists... but it's definitely not very accurate
firefoxussr is offline
Old 10-09-2013, 03:02 PM
http://www.thercracer.com/2010/05/co...l-review.html?a
Control freax make a nice rs200 shell
Qatmix is offline
Old 10-09-2013, 04:51 PM
Ed Delgado's Avatar
I assume you are talking about LMP1? If so the question is will Ferrari build one?
Ed Delgado is offline
Old 10-09-2013, 11:16 PM
Making a P1 now. Hopefully will be out soon.
roche.hk is offline
Old 10-10-2013, 07:17 AM
Originally Posted by firefoxussr View Post
This leads me to another question- could someone feasibly use a 3D printer to create limited shells? Or maybe the 3d print is just used as a master mold. I suppose the print would have to be made of something that could stand the heat of a lexan sheet all heated up.
Unless you are getting it 3D printed in metal you would have to use the 3D printed model as a pattern to take a reverse mould from, so you could then use this reverse mould to create a solid resin pattern to vacform over.
Realistically, by the time you have created a 3D model, had it printed in 3D, cleaned the surface up to a polished finish as every crease and step would be reproduced, then taken a mould from it to create the actual pattern to be used, it would most likely be cheaper and quicker to carve and shape a pattern by hand.
terry.sc is offline
Old 10-10-2013, 08:33 AM
M3Man03's Avatar
I would think this would be hard to do, since there are a lot of curves and shapes in that you can't do with a single vacuum form.
That's why a lot of F1 bodies have the side pods something separate and such.
M3Man03 is offline
McLaren doesn't have an LMP1 entry AFAIK. I'm talking about the hypercar roadcar. And LOL at Ferrari in prototype racing... They didn't even let the magnificent F50GT1 race.
I still have not found one for sale, if you know of a place....
Oh most definitely would look best with that. It seems mandatory with the amount of curves on the car. Probably 4 pieces minimum.
Old 10-10-2013, 10:21 AM
I was thinking of cheating as far as 3d work. Buying a copy of an artists P1 3d file from turbosquid dotcom then simplifying it for lexan-shell reproduction.
But then I saw this:
Do tell. Will these be available for sale? Might I see your progress?
Old 11-11-2013, 06:08 AM
Progress info please?
Old 03-01-2016, 09:25 AM
BMW M1*
Maserati MC-12*
Ford RS200*
Zender Fact 4
Maserati Bora
Jaguar XJR-15
I purchased a 1/10 pancar/f1 supposedly made by Parma. It's uncut and no decals. I'm going to copy it.
There is one now available from Killerbody, but it is off in shape in many places (quarterlight window, nose, awkward dimensions -- made for TCs, should have been pancar body really). That said the LC2 and Stratos Turbo look phenomenal... 2/3 ain't bad.
Porsche 918
Kyosho makes one. Might get one eventually, looks to be nicely detailed.
