Like Tree26Likes
CRC F1
Old 06-15-2017, 04:27 AM
  #676
Trader Rating: 41 (100%+)
Originally Posted by old_dude
Dremel with a thin wheel, cut slot in broken pin and use a screwdriver to remove it from the block. I went through a rash last winter. The blocks seem to survive with the slot in them.
A rash is the worst. It is so hard to find a good medication for it.
davidl is offline
Old 06-15-2017, 12:09 PM
  #677
I healed it with an edit. LOL
old_dude is offline
Old 06-16-2017, 07:05 AM
  #678
Originally Posted by Serzoni
Basically, you need to replace the rearmost screw in the socket for the lower arm ball with some kind of post to stop the steering block from turning too far inward. You can use a longer screw with spacers on it, or a screw coming from the bottom of the arm with a standoff on it. There's all kinds of variations that work. Team Saxo (who makes the plastics for the CRC front end) actually made hopup posts for their car that accomplishes this, but there's no Saxo dealer in the US to my knowledge, and $30 shipping for a $4 part is crazy. I'm surprised that CRC hasn't brought these over or made some of their own. Every CRC owner at our track has had the same issue at some point.
Team Saxo steering stops
Here's how I fixed mine. I used some hex-head M3 bolts that fit pefectly into the nut recess in the lower side of the socket, then I screw on some posts that I had 3d printed from the top. You could use regular standoffs that are threaded for 3mm in the same place.
I have ordered up a box of these 3mm hex head screws. The box count is 50 pcs so I have plenty extra if someone out there needs any. Shoot me a PM and I'll send them to you, no charge as long as a simple stamp will work for shipping.
I will use this as my initial step, along with the hub modifications RobK suggested and hopefully eliminate the issue.
However, if there are others out there that want to combine buying and divide the shipping cost for the Team Saxo part, let me know. I checked on their website and if we get 5-6 of us, it would drop the shipping to about $5 each. I'd be happy to buy the parts from overseas and then then send them out to anyone interested upon receipt of payment for the part cost and your portion of shipping.
If I get enough to take me up on the offer, great. If not, I'll stick with the 3mm Hex bolt mod and be happy.
LMK...
RollingChicane2 is offline
Old 07-10-2017, 09:11 AM
  #679
Any news yet on the front bulkheads for the CRC F1?
BullFrog is offline
Old 09-29-2018, 07:27 AM
  #680
MCSRacing's Avatar
well here is my thing, i replaced the front upper arms with the CRC aluminum arms ... now it destroys king pins with the lightest contact .... so far its looking like i will be forced to go back to the plastic upper arms.
MCSRacing is offline
Old 09-30-2018, 12:46 PM
  #681
MarkBurgess's Avatar
My solution has been very similar. A long 3mm screw in the rear hole for the lower ball mount, and 3mm spacers to stop the arm twisting too far back during crashes.
Been running that for since a Snowbirds a few years ago, and not broken a front upright since. I can post photos if anyone would like them?
Really looking forward to racing my WTF-1 at the opening ETS round in Vienna soon
MCSRacing likes this.
MarkBurgess is offline
Old 09-30-2018, 02:03 PM
  #682
Airwave's Avatar
Airwave is offline
Old 09-30-2018, 05:05 PM
  #683
robk's Avatar
Trader Rating: 22 (100%+)
Looks like you're going for rear traction
robk is offline
Old 10-01-2018, 02:02 PM
  #684
MCSRacing's Avatar
ok so set up a steering stop and get the CRC tamiya front wing ..... i was told by a local driver that this is what Brian told him to do, he hasn't broke a single upright since adding the wing. so parts on order and hoping for good results.
Old 10-02-2018, 08:30 AM
  #685
robk's Avatar
You can also widen the slot on the upright for more travel. Usually the upright breaks when the wheel gets forced past the limit of travel.
robk is offline
Old 10-02-2018, 09:57 AM
  #686
MCSRacing's Avatar
i will open the slot some too ... i really like this car, much more than the others i have driven, even in the wide configuration it out turns my sons xray and his buddies f6 easily. i have been breaking the king pins and bending pivot balls getting stuffed in the boards by rookie drivers ... it blows cause you're in a spot to podium and a guy 4 or 5 laps down bangs ya in the boards and then you're DNFed LOL
is anyone running the battery longwise instead of cross ways?
Old 10-03-2018, 05:14 AM
  #687
I run the battery inline and full back.
old_dude is offline
Old 10-04-2018, 06:36 AM
  #688
MCSRacing's Avatar
current layout ... wires need to be cleaned up a bit
Old 10-06-2018, 04:02 AM
  #689
Almost a pic of my car including the body color. LOL
old_dude is offline
Old 10-06-2018, 08:13 PM
  #690
MCSRacing's Avatar
i'm a blind old fart, that orange helps me see it ......
