New CRC F1 At IIC
#286
yep!, ill be there, happy to help.
#287
I'm having an off power oversteer/loose problem with the 571/572 combo. I'm running the kit setup. Side springs are about 1/2 turn down past touching. 10K in the tubes. Or is it just tires not having enough run time on them? I'm underweight of the 1050g limit as the car is still getting competition ready. I typically would switch to 575 rears, but would like to get this setup working first.
Offpower screams to me to check your drag brake or you have too much rear pod down travel which will catastrophically transfer all the weight forward going into corners. Try shortening your center shock some if you are sure your drag brake isn't too high.
#289
Come find me and say hi as well, as I'll be racing my WTF-1 as well. Just at the airport now to fly to the 'Birds from the UK.
#290
Both "Dumper's Speed Shop" and "Mario's Passion for F1" should get you rolling pretty well.
Good luck at the Birds.
Bill
Bill
#291
Hi, i've recently bought a used wtf-1. This is my first f1 after an old tamiya f103. I'm still trying to sort it out.
Just a quick question: how do i set front ride height? At the moment i'm at 6mm, i would like to go down to 4mm.
#293
Hi, thank you for your reply. Do you mean those 2 black "hexagon"-like shims? I tried to put one under the front carbon arm, but then i could not slide the front wing in. I also tried to put one between the chassis and the suspension block, but had the same result...
#295
#296
#297
I got one these on the way, can't wait. Been wanting one for a while.
#298
Got my new CRC WTF1 Wednesday. Should be ready to go for next Friday. I had to order a servo so I ordered a Futaba s9650 same as what I run in my 12th scale and my WGT. Super excited to get this car on the track. One thing it sure is tight for electronics.
#300
Dumper, what front and rear wings are you running and where can I get them?
