Old 06-25-2005, 11:55 PM   #1
DIMO's Avatar
Default Linear Or Step Charge
Hey Guys, i currently run stock and use a millenium pro charger at linear charge 6.5amps
Just wondering hat is better step charging at lets say
3-5-6.5-5 amps
Or just staying linear 6.5amp
Any input appreciated
DIMO is offline   Reply With Quote
Old 06-26-2005, 12:24 AM   #2
dakrat's Avatar
what cells?
dakrat is offline   Reply With Quote
Old 06-26-2005, 08:08 AM   #3
DIMO's Avatar
Default ib
intellect 3600s
Old 06-26-2005, 09:23 AM   #4
diha's Avatar
Does step/linear charging depend on cells used also?
Doesn't it apply to all cell?
diha is offline   Reply With Quote
Old 06-26-2005, 11:11 AM   #5
dakrat's Avatar
well, u gotta know how much capacity ur cells holds and base the charge amps from there. for ib3600 i would try 3.5, 7, 6.5, 4 thats four steps
Old 06-26-2005, 11:21 AM   #6
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
keep charging with linear method........
step charging improves runtime, and resistance also increases.....definately what you DON'T want for stock racing......
here is a test made by Racing Lines Australia with CTX cell master:
5 amps >>> discharge 3081mA / avg volts 6.986 / IR 31
step 7-0.2-4.5 amps >>> discharge 3137 / avg volts 6.871 / IR 33
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 06-26-2005, 11:47 AM   #7
dakrat's Avatar
pls explain how step charging is not good for stock class.
Old 06-26-2005, 11:50 AM   #8
all you need fot stock racing is VOLTS and LOW RESISTANCE......
runtime is something you never have to be concerned......
so if linear charge yields more voltage and lower resistance....that's the way to go.......
Salvadori Racing
Old 06-26-2005, 11:54 AM   #9
dakrat's Avatar
what cells were they using to have those numbers?
Old 06-26-2005, 11:58 AM   #10
GP3300
Salvadori Racing
Old 06-26-2005, 12:03 PM   #11
dakrat's Avatar
his step charge method is weird. 7 amp, 0.2 amp, and 4.5 amp?
this is what i use for stock racing w/ gp3300s. 3.5, 7.5, 6, 4 notice its 4 step.
Old 06-26-2005, 12:05 PM   #12
that's the recomended way by Team Much More on CTX cell master instruction manual......
Salvadori Racing
Old 06-26-2005, 12:16 PM   #13
jeepnyy's Avatar
What charger was use in this test ?
I'm wondering coz' I have CE Pitbull X3. Could this possibly work ?
Thanx
Henry E.
jeepnyy is offline   Reply With Quote
Old 06-26-2005, 12:20 PM   #14
CTX CELL MASTER......
you can use this setup, but with peak voltage settings......the much more unit mainly use temp cutoff for the last step.......
Salvadori Racing
Old 06-26-2005, 12:24 PM   #15
CRASH's Avatar
Trader Rating: 26 (100%+)
I had the Pitbulls and tried Step Charging, did not work real well at all. I now have the Orion Advantage and am using step charging.
But unlike stated above I am seeing a decrease in total IR for my cells. IB3600s and GP3300s, as well as overall increased voltage. My cells are only getting better. I am currently just running 19T and mod.
Later,
CRASH is offline   Reply With Quote
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 11:58 PM
APS Dyno Charger S3 Step-charge controlledchaos R/C Items: For Sale/Trade 2 12-16-2006 04:46 PM
APS Dyno Charger S3 Step-charge.... $120.00 killerjvf R/C Items: For Sale/Trade 3 12-14-2006 11:07 AM
Much More Cell Master CTX 3 step charge feature RaceBucks Electric On-Road 2 06-12-2006 01:15 AM
Step charging or Linear? dmayhew25 Electric On-Road 0 09-28-2005 10:34 PM
