Old 09-29-2013, 02:56 PM   #1
chasingthepack's Avatar
Default lrp x20 13.5 t ??
hi,what is the better timing insert to use in boosted and why?
thanks in advance
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 09-29-2013, 03:03 PM   #2
You dont use more timing on the motor when running boosted unless you want to cook it.
either leave it stock or even retard it slightly
PurcyP is offline   Reply With Quote
Old 09-29-2013, 04:49 PM   #3
Trader Rating: 20 (100%+)
Stock oooo insert, boost to desired temp from there.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 09-30-2013, 09:41 AM   #4
thanks guys
Old 09-30-2013, 10:38 AM   #5
means I need to adjust in the esc to get the desire setting?
sorry for hijacking this thread. I was going to ask the same question. newbee lol!
TXXT is offline   Reply With Quote
Old 09-30-2013, 10:44 AM   #6
Yes, typically in boosted classes you want to leave the motor timing alone and adjust the ESC settings for timing/boost/turbo, whatever your ESC has or calls it. Adding motor timing is too broad of a change and generally builds too much heat.
Old 09-30-2013, 10:49 AM   #7
ic.......Thanks for fast reply.
Old 09-30-2013, 04:08 PM   #8
so how much boost is safe,does the motor like high rpm or gear up?
