Speed Passion brand new Spec Racing LeMans car - The LM1 >
Like Tree35Likes
Old 12-11-2013, 08:04 AM
  #391
Trader Rating: 17 (100%+)
Originally Posted by liljohn1064
Roller! Nice easy build. Only gripe is still the front upper ball retainer strips too easy. I'd like to see it in aluminum some day.
I really don't know how that could happen....I build 6 LM1 already, and 2 SP1, except the 1st prototype version...I have not strip 1 single retainer. Not 1....
There is a direct/angle that you have to turn that retainer in....if not turning in that correctly, it will be stripped....
Solara is offline
Old 12-11-2013, 08:11 AM
  #392
Our head office LeMan event....outdoor 250 footer track, with 13.5 blinky, no traction compound on tires and no traction spray on track...raw track.
+ YouTube Video
Solara is offline
Old 12-11-2013, 08:25 AM
  #393
Full length full race version....
+ YouTube Video
Solara is offline
Old 12-11-2013, 09:23 AM
  #394
Trader Rating: 25 (100%+)
Those videos are really nice!
RS_ZACH is offline
Old 12-11-2013, 10:58 AM
  #395
liljohn1064's Avatar
It's not cross threaded. The hex strips when trying to back it off and it gets stuck. I snug the retainer down, then back it off 1/8 to 1/4 turn normally. I've done the CRC upgrade for now as I have plenty of those little retainers around.
liljohn1064 is offline
Old 12-11-2013, 12:35 PM
  #396
The hardened material (carbon reinforced) is already made to be strong enough to withstand the stripping....honestly I have tried to do it and see does the plastic still soft but I have yet to hear from those who build the LM1 has the same issue.
Does the CRC nut a direct fit..? The one from the GEN X?
Solara is offline
Old 12-11-2013, 01:35 PM
  #397
Kevin K's Avatar
Trader Rating: 32 (100%+)
Any updates on the 21.5 testing from the Chicago area crew?
Eric had a really good run down from what we found so far.
I will say that this car with 21.5 is the most fun that I have had in a while racing. After seeing the car run with 17.5 motors I think that should be an option only on larger tracks.
my car is basically box stock with a few changes...Red CRC side springs and .020 front springs. Like Eric stated getting the ride height lowered to around 4mm is a good starting point.
FYI my car was 1280 with a full size battery pack.
Kevin K is offline
Old 12-11-2013, 04:42 PM
  #398
It is an exact fit for the retainer. And I'm not cranking it down tight, just enough to slow the ball movement.
As for the kit: The plastic is a lot better, much stronger with all the new parts. I'm just unlucky.
Old 12-11-2013, 04:45 PM
  #399
Thanks Kevin and Eric. I'll be putting that info to good use.
Old 12-12-2013, 06:11 AM
  #400
celt's Avatar
Default 21.5 testing
We'll have 21.5's in our chassis here in Madison this weekend. Medium size carpet and I would say medium to low grip.
Certainly report back.
celt is offline
Old 12-12-2013, 07:12 AM
  #401
burgboyz's Avatar
Trader Rating: 70 (100%+)
10th scale servo only or will a 12th (say a ko951) fit?
burgboyz is offline
Old 12-12-2013, 07:19 AM
  #402
The chassis and servo mounts are for std size servo. You could drill another set of holes and take off the locator pin and use a 1/12 servo
ercwhtsd is offline
Old 12-12-2013, 08:32 AM
  #403
burgboyz's Avatar
Thanks.
burgboyz is offline
Old 12-15-2013, 05:43 PM
  #404
trackdesigner71's Avatar
Thanks for the thoughts and reports guys. Really I think this is good dialogue in working out this class in a way that will a) appeal to a wide range of interests and budgets and b) maximize its ability to grow. I do think having a spec/low cost option as well as a more open option will be a winner for everyone
trackdesigner71 is offline
Old 12-16-2013, 05:40 AM
  #405
kerberos451's Avatar
Got to build/drive mine this past week.
Only complaints are lack of servo saver assembly. In order to protect everything I removed the steering bell housing and attached the steering links to a large dubro server saver. Only other thing that irritated me was no Hitec servo horn, but fortunately I had a low offset steering horn.
On to the good stuff. I put a Novak 17.5 Ballistic/Edge2S in my car and its a freaking land rocket. Im running it on carpet and using just a small bit of sticky fingers the car hooked up and gives lots of confidence in both high speed and low twisty sections. It is a drivers car & after a few laps you really start bringing the times down. Its easy for my mind to turn into a computer while driving this car flat out (in the zone). Im primarily a nitro buggy guy, but I love le mans and couldn't pass up this ride. So far it seems very durable and cost effective. I do hope the class picks up. Just hoping a rubber tire makes it way onto the market.
Good Job Speed Passion...great car. 4/5 stars
kerberos451 is offline
