Speed Passion brand new Spec Racing LeMans car - The LM1 >
Like Tree35Likes
Old 12-04-2013, 08:50 PM
  #346
gsxr0311's Avatar
Trader Rating: 19 (100%+)
for those that have ran the car or seen the car ran, has anybody tried a shorty battery setup?
also, i asked a couple of weeks ago, does anybody know anything about how to keep a sensorless motor from cogging? doesn't somebody on here work for speedpassion? the motor i have is the 3500kv, help?
gsxr0311 is offline
Old 12-05-2013, 03:38 AM
  #347
celt's Avatar
All I've run are shorty packs w/ the SP Reventon-S 17.5 fixed timing combo - sensored. Battery is all the way back, with a low profile servo, ESC behind servo, reciever, then battery all in-line.
Only run on carpet though, but dailed. It simply goes where you point it.
celt is offline
Old 12-05-2013, 04:53 AM
  #348
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Big box from Speedpower due tomorrow.
BTW, I agree with the 17.5 motor for the class. I decided to to with Reventon S and 17.5R with timing motor: max timing restricted to 20*, min at 11*. Tires should be teched for minimum diameter until rubber tires come out. Now if these tires wear like iron due to their unique construction, I won't mind staying on them at all. My CRC WGT was never hard on tires. Once the camber was right the front tires wore evenly. The rears lasted a whole season and the fronts would last 3 to 4 weeks including practice. The LM-1 so far looks to be better on tire wear than that.
As far as gearing, the 17.5 would probably be better at 72/20 to 72/24 on carpet, depending on rollout of course. That's an FDR range of 3.5 to 3.0. I prefer not to let the smoke out of my electronics.
Weight - What are we going to run at?
liljohn1064 is offline
Old 12-05-2013, 06:16 AM
  #349
trackdesigner71's Avatar
Everybody that has run the car so far...have you had a chance to weigh your car before going out? I looked up the ROAR rules and for Can-Am/GTP/WSC (the best derivative I could find) and the minimum weight translates to about 1200 grams so Id go with around that as a starting point, but Im curious what the guys that have run laps with it have had for a weight
trackdesigner71 is offline
Old 12-05-2013, 06:38 AM
  #350
celt's Avatar
Stock build, no carbon anything, no alu or ti screws.
Reventon-S ESC, SP 17.5 fixed timing motor.
Airtronics low profile servo.
Airtronics reciever.
Transponder
Peak Racing 4000maH shorty pack
painted/stickered body
tires
Ready to drop on the track weight:
1263 grams
Should you spec a weight...1200grams seems pretty spot on.
celt is offline
Old 12-05-2013, 06:55 AM
  #351
Mechintosh's Avatar
Is the 72/26 Spur/Pinion combo 48 pitch or 64 pitch, do not have the car as of yet.
Mechintosh is offline
Old 12-05-2013, 07:41 AM
  #352
celt's Avatar
48...durable
celt is offline
Old 12-05-2013, 08:32 AM
  #353
Mechintosh's Avatar
Originally Posted by celt
48...durable
Imagine my surprise when I tried to fit a 72 tooth 64 pitch spur on a tamiya axle... I was like what??? LOL...
Thanks for the clarification.
Old 12-05-2013, 09:23 AM
  #354
Would probably spec a minimum for both LMP and LM1 just to put everyone on a relatively even plane to start.
Old 12-05-2013, 09:33 AM
  #355
celt's Avatar
I think all of us have done that...
celt is offline
Old 12-05-2013, 02:11 PM
  #356
1263 grams
You guys make me feel like the fat kid at prom again, wait, I am a fat kid
1340g with full size battery and full size servo, Novak Club Spec and 21.5 SS, the Ballistic is a little lighter, not much.
ercwhtsd is offline
Old 12-05-2013, 03:49 PM
  #357
Well we would probably only spec minimum weight because everybody would be running different gear.
Old 12-05-2013, 06:13 PM
  #358
celt's Avatar
A shorty pack is almost worth a 100g right there...
1240g? Not bad.
celt is offline
Old 12-06-2013, 01:33 PM
  #359
Thanks Eric from THE TRACK @ Harbor providing this carpet setup.....
Solara is offline
Old 12-06-2013, 01:41 PM
  #360
gsxr0311's Avatar
Originally Posted by robk
You can use the tamiya washer if you are not getting the diff action you want.
http://www.tamiyausa.com/product/ite...uct-id=3455940
i finally got this "thing" in the mail. question though, does this just replace the washer or does it replace the washer and spring washers? is it like some sort of crush washer and i should only use this part? help?
gsxr0311 is offline
