Old 09-25-2013, 06:35 PM   #1
silverbmr's Avatar
Default Airtronics 92524 Binding Help
Need help in binding an airtronics 92524 with my radio. I've followed the steps but still unsucessful. after i go through this step : "depress and HOLD the transmitters blind button until the receivers bind LED begins to flash radiply. The binding process is successful when the recievers bind LED is solid". the problem is when i do this the LED doesn't become solid. am i doing something wrong?
what to do?
silverbmr is offline   Reply With Quote
Old 09-25-2013, 11:14 PM   #2
what to do?
Which transmitter you are using? And have you set the transmitter to FHSS2 mode?
roche.hk is offline   Reply With Quote
Old 09-26-2013, 03:34 AM   #3
silverbmr's Avatar
am using a Sanwa MX sport
Tamiya TT01 E | M05 S Spec | TT02B
Old 09-26-2013, 12:56 PM   #4
Trader Rating: 27 (100%+)
1) Go to the binding menu on the radio. Make sure it's set to FHSS-2.
2) With the system off, hold down the bind button on the receiver.
3) Engage the binding thing on the transmitter.
4) While holding down the bind button on the receiver, turn the system on.
5) Press the bind button on the transmitter again.
That should work. I've got two of those and that's how I always worked for me.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 09-26-2013, 12:57 PM   #5
Old 09-26-2013, 01:20 PM   #6
Through which transmitter that you will be utilizing? And possess a person fixed your individual transmitter to be able to FHSS2 execute?
[url=http://www.suitusa.com/]cheap woman suits[/url] ~!~ [url=http://www.suitusa.com/]slim fit suits[/url] ~!~ [url=http://www.suitusa.com/]Suit Sizes[/url] ~!~ [url=http://www.suitusa.com/]suits for sale[/url]
jerinbd445 is offline   Reply With Quote
Old 09-26-2013, 11:30 PM   #7
oh, the mx sport you cannot select different system for receiver.
http://www.airtronics.net/media/uplo...ing_Manual.pdf
Pg 11 any help?
Old 09-26-2013, 11:51 PM   #8
Geezatec's Avatar
Depress and hold until the LED is solid. Believe you quit too early. It does take a few seconds to search for the Freq. It not instant. Start from the beginning Depress and hold till its solid. Could take up to 10 seconds.
Geezatec is offline   Reply With Quote
Old 09-27-2013, 12:45 AM   #9
silverbmr's Avatar
thanks fro the help rc gurus. i was able to make it work.
