Street Jam SJF01 Formula 1. Niiiiiiiiice!
#46
Yes rc-art sells all the SJ options you need, and yes get the rear spring option kits, qty2
BUT, for the rear axle the Speedpassion steel and/or Carbon ones are MUCH better as they are a one piece pinned axle like a pan car and spin much truer and are a perfect fit no fiddling.
also the Speedpassion carbon uprights Rev B are much better than SJ ones as well, stiffer and reinforced in the pivot ball area
#47
also I can get the tresery sp1 for a great price locally but only a few dollars less than the SJ version and is it really worth getting the SJ version?..as i struggle with rear grip at the moment on low grip asphalt with my 104w gp on foams..cheers.
#48
Q: ok..so the axle that comes in the SJ kit isnt the speedpassion one?
A: Correct, it is different, it is a two piece more similar to the tamiya one
Q:do rcart sell the speedpassion one? as well as the carbon reinforced bits?
A: No, I order direct from speedpassion, http://shop.speedpowerrc.com/
Q:also I can get the tresery sp1 for a great price locally but only a few dollars less than the SJ version and is it really worth getting the SJ version?
A: YES, get the Street Jam it is MUCH better. The rear has more grip and with any F1, like the Speedpassion, that uses a rear center pivot, it tends to need adjustment every race round to be at it's best. The SJ is a different better design it doesn't move with crashes or hits etc
The SJ is a Speedpassion front end and a new better rear end. The rear is totally different except the Speedpassion rear axle is compatible and better.
#49
cheers and sounds like the way to go.
#50
#51
I like to buy a streetjam!
any musthave option parts.
Or parts from speedpassion that are better?
I will use it with rubber on a large carpet track.
21.5 t brushless.
21.5 t brushless.
#52
How can I online order this chassis?
Best regards
Best regards
#53
rc-art.net sells it, they are quick and reasonable, great customer service, they are in Japan
The only Speedpassion parts that are better are the Speedpassion rev B front uprights and the Speedpasion Steel or Carbon Rear axle
option parts: the works 2 shocks and the machined 4 hole piston set
#54
Got mine yesterday and built already.
got it in about a week from rcart in japan.
nice bit of kit and i got all the hopups as very cheap and get extra arms as well just in case.
#55
#56
Heres mine..put silvercan back in from 104 until 21.5 Team Powers turns up.
Nice build.
Nice build.
#57
Anyway thanks
#58
#59
