Street Jam SJF01 Formula 1. Niiiiiiiiice!
#421
Yes, check the left motor pod plate, opposite of the motor mount plate.
It is not designed that well and the aluminum used is not that strong, so it could bend in a crash. I was wondering too when I had the links equal but my pod was tweaked to one side. I found out the left side pod plate was bent, moving the upper link mounting plate more forward on one side. Even a slight bend will throw off your pod. Check it out and let us know. I replaced the pod plate with a new one and now its perfect. I also carry a spare just in case.
#422
Ok, latest update.
I have installed the STJ bladder front shocks on the IFS front end,
Initial thoughts were it was fantastic, well it was in practice anyway.
As soon as the sun went down and track went cold I just couldn't get any front bite out of the tyres, it would just understeer. This was with soft fronts, and the hardest springs. I dropped down a spring rate for the final but was worse.
2 days later and different track and a little heat during a day race the car was back to being great and on the pace.
I don't normally heat the Shimizu F1 tyres but I think I am going to have to start during winter
Ill see if its any better with warmers this Friday night.
#423
Mine came pre-tweaked as well. It's not a well-designed part. Basically they took the original Speedpassion part and added a boss for the lower ball connector for the shock. I put it in a vise and bent it back to something approximating square. I ordered a couple more from RC-Art, and hopefully those are not defective as well.
#424
#426
Hi all,
Indoor season is here and I will be running on carpet.
Is there anybody who has a good base setup for carpet? Can you share it?
I addition to that I was wondering why almost everybody is locating the battery back. One of my main struggle with this car has been to have turn in (Ride is our controlled tires). My idea is that having the battery forward will help to have appropriate turn in, even thought the mid-end steering would be less (but I guess it can be compensate with the rear links?)
Thank you in advance!
#427
Hi all,
#428
I'm running exotek upper arms with tamiya pins' and steering blocks on the stock lower arms,soft springs,7*caster,2*camber,3.5mm spacer on rear upper arm mount. That worked great for me.(med high bite carpet).
#430
Actually, I was thinking in also using the exotek upper arms with tamiya pins and steering blocks!
It would be great if you can give some more details about the whole setup
Ride height (front and rear)
Ride height inserts
Upper link (high or low and length)
Rear shocks (oil and springs)
Battery position (forward, middle or back)
I am new on carpet, so I would really appreciate your input!
#431
Thank you very much!
. For instance:
Ride height inserts
Ride height inserts
2.0 inserts spacer in the upper pos.
Upper link 27mm upper position 1mm spacer rear ball
700 oil v2 shocks w 4 hole pistons medium shock end
Battery front esc rear batt conectors to the front
Exotek servo extension.
Hope this helps.
#432
It helps a lot!
#433
Could you post a photo or give me some more details around how did you installed the exotek upper arms and the tamiya pins and steering block? In concrete I after how many spacers do I need to put below and above the steering uprigth
Thank you
#434
That plus the lower arms mounted as per instructions on the car, except do not
Put the 1mm shims' between the chassis and suspension plate. I think that's about it. Hope that helps .
#435
We run 4.5mm ride height,for that I use 2.5mm above the upright (which controls ride height) and 3mm below the upright (which controls droop).
What tamiya pins are you using? I using tamiya 54160 and I use 3mm under the uprigth, but I need to add 6mm above the uprigth. Am I doing something wrong? Or is it because you add 3.5 mm above the exotek arms to compete the length of the pin?
Thanks a lot
