Old 09-22-2013, 08:28 PM   #1
Default in what order do i set my car up?
droop, camber, toe ,ride hight?
any help would be great
TeamThibault is offline   Reply With Quote
Old 09-22-2013, 10:25 PM   #2
Usually I do roll center, downstop, droop, ride height, camber, toe, then check everything again....
www.beamcat.com
beamcat is offline   Reply With Quote
Old 09-22-2013, 10:40 PM   #3
droop, camber ,ride hight, toe
thats my order
starrx is offline   Reply With Quote
Old 09-23-2013, 02:19 AM   #4
heretic's Avatar
Not sure if this is considered part of "setup" but IMHO tires should always be your first concern. Gluing and saucing. But that's assuming the rest of the setup is not too far off. With good tires and the box setup it's rare to get something undriveable. I'll let the setup gurus chime in as to what to change and when.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 09-23-2013, 03:21 AM   #5
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
droop, ride height, tweak, camber for me...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 09-23-2013, 03:26 AM   #6
tc3team's Avatar
I was going to say the same thing but assumed the OP had already got the right tyres to hand.
No amount of time changing setup will help if you're tyres/prep are not good.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 09-23-2013, 05:24 AM   #7
daleburr's Avatar
Detweak chassis on a flat surface
Left-right balance (on Hudy balance pins)
Droop
Camber (just get it in the ball-park for now)
Ride height
Cambers again (adjusting the ride height changes the camber)
Corner weight
Recheck ride height
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 09-23-2013, 07:13 AM   #8
yokemad's Avatar
Droop
Ride height
Corner weight
Recheck ride height
+1 Check the tweak before doing anything else!
yokemad is offline   Reply With Quote
Old 09-23-2013, 09:29 AM   #9
What is considered good tire prep?
Sean B. is offline   Reply With Quote
Old 09-23-2013, 09:43 AM   #10
Suspended
Whatever the order, rechecking often is essential....
bertrandsv87 is offline   Reply With Quote
Old 09-23-2013, 11:35 AM   #11
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Why droop before ride height? Wouldnt you want downtravel to be reflected by ride height? Also tweak can be present in the pressures of the shock springs and rollbars. I would think you would adjust this out as one of the final steps.
I might be wrong but this seems to work for me;
Chassis trueness on glass table. Downstop set equal using blocks
Ride height
Camber caster ect
Tweak check by compensating spring and rollbar pressures. Usually a lift test. Which should accurately reflect this as the downstops have been set equal.
Then id recheck camber caster if they changed after tweak check
Set droop over right height and then recheck on downstop block for accuracy.
Interested in this diacussion though. Everyone does things different.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
