Airbrush Information and Questions
#91
What colors?
Did you spray a VERY fine... if not clear coat first so it would have something to start the bond?
How many coats did you spray?
Did you back it?
Did you back it?
#92
I did use a very fine first coat of each color, applied about 3 coats per color, backed it twice with pactra silver.
#93
I use a Badger 150 and Faskolor paints.
Usually I back the water soluble color with some white or silver Tamiya paint.
It does not scratch like the Parma paint or any other water soluble paint.
The compressor is a very small (noisy) one that I used for detailed illustration work (a former life eh eh).
The results have been very rewarding sinde the first try.
This one was very easy to do but the race ability of this body is close to none. Just a display model, now
Based on Tosolini car. However not a very good body to race. Just nice...
A copy of Marui car, but nice anyway
The trimming on this car drove me mad...
#94
Those are very nice antinop, I wish I was that good!
#95
Suspended
Originally posted by Speedo
Well, it scratches all the way through, so I'm guessing that's not good! I'll try putting another coat of backing on.
Are you using a hair dryer to help set the paint before you do another coat?
If not try it, I have never scratched one of my painted bodies after doing it this way.
#96
yup, I used a hair dryer too...It's not that bad now, seems to have dried out a bit more over the past few days...
So, what do you guys think for a first airbrushing attempt? The quality isn't great, the camera is screwed up, but the sides and front are carbon fibre.
Speedo
Speedo
#97
Here is a better one
#98
Well, I figured out what to use to back the bodies. Urithane (sp?) Not poli-urithane, but urithane. I haven't tried it yet, but it was recomended to me by a really good painter at our track. I saw one of his bodies he backed with it, and it looks good, it dried clear, hard and flexible, and water-proofs the paint.
Josh
Josh
#99
what if i only have a single action airbrush? will i be able to do those flame thingies?
#100
You should be able to do flames with a single action airbrush...Just draw up some flames and mask it out...Or buy some pre-cut ones from the likes of parma.
I was recomended a great thing to use in place of masking tape, draw liner/wall backing. I found a nice big roll of clear stuff at bi-mart for about 3 bucks. It has much cleaner edges than masking tape, and you get lots! Plus, it's clear!
Josh
Josh
#101
Re: Carbon Fibre look
Originally posted by Geppetto
I've found the particular matting used to emulate the carbon fibre look, but what colors do I use (black, silver) ?
http://ourworld.compuserve.com/homep...aliti/TB01.htm
http://www.interlog.com/~khartlen/tips/cf.htm
Thanks!
Regards,
Alvin
#102
I would let the parma dry at least overnight before backing with the Pactra.
You guys might want to look into Createx Autoair water based paints also. Very similar if not the same as Parma but comes in bigger bottles, cheaper more colors. Look for it in your local art supply stores. Make sure its Autoair for non-porous surfaces used to paint skis, snowboards, helmets etc..
For the person who thins the Parma with denatured alcohol, did you do this on metallic paints? If you did, did the flakes clump up? I found the alcohol was bad for metallics.
#103
Yes with practice you can do anything.
#104
Trips
#105
Originally posted by Trips
I've been thinning the Parma Faskolor with denatured alcohol, but I haven't used any metallics so I don't know what the result would be.
Trips
Trips
