Old 09-24-2013, 05:27 PM   #76
Originally Posted by howardcano View Post
I modified my previous post to include open tires with a minimum diameter.
Can you provide info or links to the Colt and Chevron bodies that you have in mind?
www.colt.com.tw
www.chevronmodels.com
Colt bodies can be found on Ebay. RCMart has them, Dinball has them.
Chevrons can be found at The Border and Bonzai Hobbies
Just a note about the minimum diameter thought. You'll have some people say that it's bad because they want to use the tire until it's right down to the wheel. I've noticed this in Oval racing.
Have to wonder though, it's really not very different in Touring Cars. In VTA for instance, once you've worn the tread off; the tire is illegal.
rctrackman is offline   Reply With Quote
Old 09-24-2013, 06:01 PM   #77
LonnyJ1950's Avatar
Back when one of ROAR's missions was to "Promote competition between scale appearing cars" there was a minimum diameter rule for every class, For 1/12TH it was 2" rear and 1 3/4" front. !/10TH was 2.25" I think, but I don't remember if that was front or rear or both. Yes, it affects the handling, but it's the same for everyone, and what's the difference if you cut off half the rubber before you run it or throw away half the rubber when it gets too small?
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 09-24-2013, 06:27 PM   #78
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by BullFrog View Post
You can't regulate a minimum tire rule. It does not allow anyone to get the maximum about of run tire on their tires.that is a really silly rule.
It's very easy to regulate, using a dial caliper. But it still might be silly!
I race oval locally with the organizer for the BRL, and have learned a bit about it. The oval guys aren't at all concerned about getting the maximum number of runs out of the tire; the want maximum performance, which in this case is usually the smallest tire possible to reduce the rotating mass. For big events, it's not unusual for the fast guys to take a new tire and cut off all the rubber until there is about one good run left on it. That's ridiculous!
Very well said! But there is one difference: when the tire is run down to the minimum diameter I have suggested in WGTP, it's just about the right size to start using in a different class! So it is still possible to get full use out of it. I already do this with my tires. I run them in Breakout and Legends classes, then put them on my BRL NasTruck or WGT.
None of these rules are set in stone; it's way too early for that. They are just starting points for our conversation.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-24-2013, 06:41 PM   #79
howardcano's Avatar
Originally Posted by terry.sc View Post
If someone suggested just hacking off the kick up and mounting it higher up as a wing, there is no way I would have thought it would look as good as that. Personally I would still prefer a decent size wing, but that looks a lot better than the original body.
That's why they call me the hackmeister... I think.
It worked well enough that I wonder if that's what the designer intended. Also, I could have made it wider by just changing where I cut. This width was just a guess.
Howard Cano
Old 09-24-2013, 06:42 PM   #80
If you knew when that tire rule was in effect I'll be glad to look it up for you. I've got every rulebook that Roar did. the only time there was a mim. size was when the car was to low and dragging the chassis. Before there was ride height adjuster in 1/12th.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 09-24-2013, 06:54 PM   #81
howardcano's Avatar
Thanks for the links to the bodies, guys. They are gorgeous! I added them to the list.
Howard Cano
Old 09-24-2013, 07:41 PM   #82
LonnyJ1950's Avatar
If you knew when that tire rule was in effect I'll be glad to look it up for you. I've got every rulebook that Roar did. the only time there was a min. size was when the car was to low and dragging the chassis. Before there was ride height adjuster in 1/12th.
You're really testing my memory here, but since my last ROAR badge expired in 1991, I would guess late '80s. For a while there was even an argument about if they should pass before or after a run.
Lonny
Old 09-25-2013, 12:02 AM   #83
2wdrive's Avatar
If you run on asfalt you can run the tire from big to the rim without any problems.
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 09-25-2013, 02:45 PM   #84
I'd like someone to paint this for me and I'll need it in 24 hrs. !
RCHSR: Radio Controlled Historic Sportscar Racing-porsche-lmp1-wallpaper.jpg
Old 09-27-2013, 05:49 PM   #85
Ed Delgado's Avatar
Jaguar XJR8
RCHSR: Radio Controlled Historic Sportscar Racing-image.jpg
Ed Delgado is offline   Reply With Quote
Old 09-27-2013, 05:51 PM   #86
Ed Delgado's Avatar
Porsche 962C
Old 09-27-2013, 06:32 PM   #87
NutDriver's Avatar
Trader Rating: 19 (100%+)
Love that Silk Cut Jag!
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-27-2013, 07:37 PM   #88
tommy911t's Avatar
Trader Rating: 50 (100%+)
Thumbs up
YES! This reminds me of my dream category:
LMP1 bodies on 1/10 awd touring car chassis, rubber tires, with lay down shocks!
GO PORSCHE 2014!
tommy911t is offline   Reply With Quote
Old 09-27-2013, 07:58 PM   #89
Try it with 2 wheel drive. Nothing like those beautiful fat tires out back and having a relatively simple car that does what a race car is supposed to do.
Old 09-27-2013, 10:58 PM   #90
+1
RoyU is offline   Reply With Quote
