Xerun X1A questions
Old 09-20-2013, 05:26 AM
Biff73's Avatar
Default Xerun X1A questions
I bought a Xerun X1A 120A esc & 9100kv sensored brushless motor installed on a tt sparrowhawk vx,but it spins 360 degrees out of control at full throttleLooking for a new touring/drift car or buggy that can handle my esc & motor,what I have in mind is HPI sprint 2 or thunder tiger sparrow hawk xb,which is more ideal?thanks in advance
Biff73 is offline
Old 09-20-2013, 05:36 AM
ThePanda's Avatar
Trader Rating: 67 (100%+)
kv is way to high. you will have to gear down so much to make it drivable. better tires will also help.
ThePanda is offline
Old 09-20-2013, 05:45 AM
Biff73's Avatar
I'm using 48 pitch 26t pinion & 72t spur gear,will changing to a 19t pinion help?
Biff73 is offline
Old 09-20-2013, 06:16 AM
ThePanda's Avatar
that might help. really it would be better to switch out the motor.
ThePanda is offline
Old 09-20-2013, 04:23 PM
Biff73's Avatar
I'm a speed freakPrecisely why I bought this 9100kv brushless combo,rather than switch out the motor,I would prefer to look for an ideal rc car that can handle it
Biff73 is offline
Old 09-20-2013, 05:12 PM
ThePanda's Avatar
did you trim it (the car) up? that and new tires and it should handle it. if tou want a new car the tamiya ta series or a spec r, or 3racing car mould handle the power fine. all can be had for cheap
ThePanda is offline
Old 09-20-2013, 06:05 PM
TB03Racer09's Avatar
try programming the esc (put a lower punch setting) and get grippier tires
TB03Racer09 is offline
Old 09-21-2013, 06:26 AM
Biff73's Avatar
I'm at level 1 punch setting,using thunder tiger fire blade tires,what do you mean by trim?
Biff73 is offline
Old 09-21-2013, 10:06 AM
ThePanda's Avatar
Well you said its spinning out. Did you set camber equal left to right and front toe equal left to right?
ThePanda is offline
Old 09-21-2013, 12:25 PM
Biff73's Avatar
Other changing to soft suspension springs & lowered ride height,I left everything else default,sorry noob here
Biff73 is offline
Old 09-21-2013, 01:25 PM
ThePanda's Avatar
I just realized that car has solid links oops on my part. how soft are the springs? what is the rate on them? did it spin out with the harder stock springs?
i think that a set of softer tires is the answer.
ThePanda is offline
Old 09-21-2013, 02:11 PM
Biff73's Avatar
Its tt 4.2 coil medium tension springs,the stock are too hard & stiff & makes the car unstable,ordered high grip tires,but out of stock,would foam tires help?
Biff73 is offline
Old 09-21-2013, 03:01 PM
ThePanda's Avatar
foams? yes but they dont work well on a street they fall apart. what oil are the shocks filled with? if you want to go fast. then put softer oil in.
ThePanda is offline
Old 09-21-2013, 03:45 PM
Biff73's Avatar
Think its silicone oil,tt reccomends it,only used tamiya aw grease on spur & pinion,left everything else default
Biff73 is offline
Old 09-21-2013, 07:36 PM
ThePanda's Avatar
what weight or viscosity of oil in the shocks? dont put anything on the spur or pinion its not needed
ThePanda is offline
