Old 09-16-2013, 08:39 PM   #1
Adam B's Avatar
Default JACO Touring Car Tires & Wheels
I was wondering if anybody has an issue with the hex in the Jaco rim stripping out? I have noticed this issue for about a year now. I was told it was possible my cars hex being worn, but my cars (xray T4) were brand new. I have replaced them (hex) and still have the issue. I know serpent cars that have the same issue, and heard of others as well. I run mainly 17.5 blinky.
If you have had this issue, what did you do to prevent it?
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 09-16-2013, 08:47 PM   #2
mkiiina's Avatar
Trader Rating: 69 (100%+)
Are you sure the wheel isnt backing out the nut some and stripping? Are you running the serrated wheel nuts or smooth? How much play is there in the hex?
mkiiina is offline   Reply With Quote
Old 09-16-2013, 08:54 PM   #3
I've destroyed a lot of Jacos on my Serpent, but never had a problem with the hexes. The hex is not very deep, so if you're running more than 1mm of wheel spacers, I could see there potentially being a problem.
Team Serpent
Steve S is offline   Reply With Quote
Old 09-16-2013, 08:58 PM   #4
Adam B's Avatar
I run the serrated wheel nuts and have this issue. My friend uses the flat nylock nut and has the same issue. Also the wheel nut is always tight when the car comes off the track.
I am running no spacers between the hex and wheel.
Old 09-16-2013, 10:01 PM   #5
Jerz616's Avatar
Trader Rating: 49 (100%+)
I remember when we used to run jaco's at our club. It seemed the hex was just a hair to big and when you put a lot of force on it it would slip one rotation. I kept mine as tight as I could and it still did it now and the. We ended up changing to sweeps although not for this reason.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-16-2013, 10:29 PM   #6
Adam B's Avatar
I hear ya, but my biggest concern is this is the spec tire for birds and I want to resolve this problem before then so I can practice with these tires.
Old 09-17-2013, 05:43 AM   #7
Jerz616's Avatar
I hear ya. I don't think there is a fix. That's what we are using this weekend in Nashville so I hope it doesn't cause any issues.
Ryan Gracey
XRAY XB8'14
Old 10-18-2013, 02:31 PM   #8
Adam B's Avatar
After racing at Vegas, did anybody have an issue with the hex not holding up? These tires are honestly the reason I am considering skipping snowbirds.
Old 10-18-2013, 02:47 PM   #9
I didn't hear of any issues - you should go to Snowbirds. See you next week at the Gate.
Regards,
Ian
Team Yokomo, Team ORCA, Solaris Tires, PROTOform, ProSpec
ADHSponser is offline   Reply With Quote
Old 10-18-2013, 03:06 PM   #10
syndr0me's Avatar
Trader Rating: 32 (100%+)
I've burned through thousands of dollars in Jaco and never had a single issue with a rim. It makes me wonder if there's something unique to your track/boards that might be causing an issue.
syndr0me is offline   Reply With Quote
Old 10-18-2013, 03:14 PM   #11
locked's Avatar
Too many board meetings?
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 10-18-2013, 03:52 PM   #12
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I have came off the track ( thunder Rc Nashville Tn ) many times with a wheel wobbling and found it to be a wheel twisted on the hex. Tho I feel its from board meeting its always the fronts and when I have this issue I'll either rotate tire to rear of car or put a drop of med Ca glue inside the hex and let it flow all around the hex then dry then remount on car . this has got me thru the race days so far . never felt as if the rim was keeping me out of the A...
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 10-18-2013, 04:15 PM   #13
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I have had the rim and hex do this. I do think maybe the rim is a bit softer than other rims. A friend also had same issue. We just rotate the tire in the rear. It has never fully stripped but I do see the problem. The adding CA sounds like a good idea to try.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 10-18-2013, 04:20 PM   #14
Colbynobo's Avatar
Trader Rating: 19 (100%+)
Hmm. I'll have to take a closer look at the hex, I keep having a problem with the left front wheel on my T3 coming loose. I had assumed until reading this post that it was something that I was doing even though I tighten it at the beginning of each run. Now I wonder if it's a bad hex. I run at the same track as syndr0me, but I have significantly more board meetings than he does.
Colbynobo is offline   Reply With Quote
Old 10-18-2013, 05:39 PM   #15
Jerz616's Avatar
As far as the hex goes I think jaco's are just a hair bigger then others. I always have a little play around the hex whereas with the sweeps we changed to they set a tight fit from the start.
Ryan Gracey
XRAY XB8'14
