ORION R10 Vortex DSB R program box >
Old 09-16-2013, 06:25 AM
Trader Rating: 24 (100%+)
Default ORION R10 Vortex DSB R program box
Guys,
I have a Orion DSB r program box for an Orion Vortex R10(120 amp) speedo model number 65101. When I plug the program box into the top sensor wire outlet on the speedo using the provided wires, it lights up with a dim blue black light, but no words are present on the LCD display and the buttons do not do anything. I have replaced the sensor wire twice and get the same results. I then tried to plug the program box into the receiver wire out of the speedo and the words team orion and the version number come up, but again, the buttons on the program box do not do anything... its like its stuck.
I have tried it with and without the motor sensor wire connected and get the same results. This box is new and not damaged from what i can tell. I tried to call horizon hobby and they dont know whats wrong either. Has anyone out there experienced something similar? Thanks so much for any responses.
gocoogs is offline
Old 09-16-2013, 08:48 AM
Are you using a 1 cell lipo? I had the same issues with the box until I powered it with a 2 cell battery.
Hyper One is offline
Old 09-16-2013, 09:12 AM
nah, its a fully charged 2 cell battery LIPO.. not sure what is going on...
gocoogs is offline
Old 09-29-2013, 02:01 PM
chasingthepack's Avatar
only use 1 sensor wire ,dont leave one connected to the motor,just direct to the box,that should cure the problem,what i do is disconnect the sensor wire from the motor and plug the adaptor into that,have you got the adaptor that has a servo plug on one end(plugs into side of programme box)and a black sensor socket on the other?
chasingthepack is offline
Old 09-29-2013, 02:29 PM
Jerz616's Avatar
Trader Rating: 49 (100%+)
I had this issue when I first bought one about a year ago. I had to update the software on the speedo and it fixed it. The only other time I had the issue was when one of the sensor ports on the ESC went bad.
Jerz616 is offline
