Old 09-14-2013, 08:18 PM   #1
Typeone's Avatar
Trader Rating: 30 (100%+)
Default Why does my R1 Wurks fan pulse after a few minutes of running???
I've been having an issue with my R1 Wurks high speed blower fan 30x30. The fan runs fine but after a race or so I can hear the fan pulse. I contacted R1 Wurks and there going to send a replacement fan I was just wondering if anybody else had this problem.
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 09-14-2013, 08:51 PM   #2
Jerz616's Avatar
Trader Rating: 49 (100%+)
Some people have been having that issue if you have the fan to close to the motor. With the high strength magnets in our rotors they can cause some interference with the fans. I was told to mount the fan at least 10MM away from the motor. Maybe that will help you.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-14-2013, 09:00 PM   #3
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I've had the same issues but it seems to be related to heat in my case. Indoors on carpet I haven't had any problems. I ran the same car and motor outdoors in the heat and then noticed it. Something to consider.
Old 09-14-2013, 09:18 PM   #4
NR
NR's Avatar
Trader Rating: 52 (100%+)
Yes, I've had the same issue, or a little different, mine starts shorting out and stops the receiver working
NR is offline   Reply With Quote
Old 09-14-2013, 09:28 PM   #5
syndr0me's Avatar
Trader Rating: 32 (100%+)
What ESC?
syndr0me is offline   Reply With Quote
Old 09-14-2013, 10:03 PM   #6
Typeone's Avatar
I'm running outdoor with kill shot 17.5, SpeedPassion Reventon Pro, Futaba 4pL system, Savox 1251 servo. I have a power capacitor for the esc and a voltage protector. I'm running outdoor asphalt. Here's a picture of how far my fan is.
Old 09-15-2013, 03:36 PM   #7
Typeone's Avatar
Anybody else have this problem??
Old 09-15-2013, 05:06 PM   #8
Suspended
No glitch capacitor connected to your receiver ???? Maybe your bec needs one...
bertrandsv87 is offline   Reply With Quote
Old 09-15-2013, 09:34 PM   #9
Typeone's Avatar
Yeah there's a voltage protector connected to the receiver.
Old 09-15-2013, 09:45 PM   #10
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Maybe cuz its a R1 Wurks fan!
Josh-n-ya is offline   Reply With Quote
Old 09-15-2013, 10:14 PM   #11
frank b's Avatar
Could be at high speeds the fan is not balanced and it is causing it to vibrate. The shitty thing is you can pay the extra $ and a cheaper fan will not do that. It's all luck to get the right one..
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 09-15-2013, 11:17 PM   #12
syndr0me's Avatar
I've only seen it happen in cars with reventons.
Old 09-16-2013, 01:16 AM   #13
hana166's Avatar
Some of my Yeah racing fans slow down and eventually stall during the run. Some don't. This is really annoying. My MM high rev type doesn't stall. Honestly don't know why this happens. Could be down to poor quality, but also could be the design of the fan in which case it doesn't matter how much you spend. Did I mention this is really annoying?
hana166 is offline   Reply With Quote
Old 09-16-2013, 08:30 AM   #14
Trader Rating: 20 (100%+)
Does it on my LRP's too.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 09-18-2013, 12:47 PM   #15
Typeone's Avatar
Has anybody tried the Yeah Racing 30x30mm Tornado high speed cooling fan. I've heard good things about them and I know they don't push out as much air as the R1 Wurks fan but I need a consistent fan. Also has anybody tried the Active Hobby 30mm 5v fan?
