Old 06-20-2005, 02:45 PM   #16
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by howard hudson
at socal thats all that works. due to there is so much of it in the asphault its self ( years of build up)
I knew they had a special air freshener built right in...Man they should cut it up and sell it on eBay they could make a fortune...Then they can acctually lay asphalt flat on the ground and get rid of the bank....I know I will catch heat fromt he pan guys but come on...Per racer entries are there more TC or Pan?
-Stephen <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-20-2005, 02:59 PM   #17
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
paragon works good for indoor, but for outdoor i use red dot,and tweak 2000(both made by Trintiy) mixed together...works great outdoors on foam
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Old 06-20-2005, 03:01 PM   #18
axel's Avatar
what's ur guys's opinion on tq orange?
axel is offline   Reply With Quote
Old 06-20-2005, 03:01 PM   #19
fatdoggy's Avatar
12th stock on ozite - I've been running niftech for a few months. It takes one run for them to rub in and start working well; but after that they are hooked-up for the rest of the day. Plus niftech doesn't stink as much as paragon.
fatdoggy is offline   Reply With Quote
Old 06-20-2005, 03:30 PM   #20
For rubber tire, I use tire tweak after cleaning w/ motor spray or buggy grip. Let it sit for 30+ minutes then wipe it off. For foam tire I use Foam Factor from ARC. Let it sit for about 10 minutes before your run, and then wipe it off just before you go up for your heat. The stuff has crazy traction. I usually have to clean the tires every run or two though (usually with motor spray), because the tires get gummy.
Jay Dub is offline   Reply With Quote
Old 06-20-2005, 04:09 PM   #21
danjoy25's Avatar
Trader Rating: 37 (100%+)
Only use TC-3 and works great on rubber and also gives you a high feeling .
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-20-2005, 04:56 PM   #22
edseb's Avatar
Not only what tire sauce you use, but how it is used. You can ask 10 people how they apply Paragon, and you'll get 10 different methods, and even more with different tires. Sorex is great with Paragon, but doesn't really work well with Takeoffs ( I use Simple Green on those). On Sorex's, I sauce at least 4 heats in advance, then if there's some that didn't soak in, I'd wipe them or use tire warmers and bake it in. It also depends on the track.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 06-20-2005, 05:01 PM   #23
x-ray=speed's Avatar
Default simple green
Hi, i use simple green on 36 sorex in mod, i just put it on and clean the tyre with it then put my warmers on and have awesome grip from start to finish.
Joel
x-ray=speed is offline   Reply With Quote
Old 06-20-2005, 05:01 PM   #24
danjoy25's Avatar
I do the following:
1) Apply traction compound and let dry for 10 mins
2) Use tires warmers to for 10 mins
3) Apply traction compound again while tires are warm and let dry for another 10 mins
4) Use tires warmer again until my race starts.
Old 06-20-2005, 06:57 PM   #25
VenomWorldOrder's Avatar
Originally Posted by danjoy25
I do the following:
so are you going to let me use this method during the winternats or are you going to go stingy on me!!??
VenomWorldOrder is offline   Reply With Quote
Old 06-20-2005, 07:05 PM   #26
danjoy25's Avatar
I think you need something with a harder front & side bite. Hopefully we won't be in the same heat so I can pit for you and will apply CA glue on your rubbers before I put your car on the starting grid.
Old 06-21-2005, 10:30 AM   #27
Suspended
Trader Rating: 28 (100%+)
Tq orange doesnt work well for outdoors axel.Not for the tracks you race at.Save it for Gilroy.Try Trinity Death Grip.It works very well.We have been testing it at both Hobbytown races and at Rccar track.We also have used it at night on a VHT prepped surface.Too much traction!I apply the stuff 5 minutes before my heat and it dries in about 3 minutes,no need to wipe if you didnt get too crazy.Works awsome.Remember to clean your tires first.Motor spray and a rag works well.
racenut123 is offline   Reply With Quote
Old 06-21-2005, 06:17 PM   #28
axel's Avatar
thanks john.
Old 06-21-2005, 06:22 PM   #29
axel's Avatar
how about wd-40 for cleaning off your tires?
Old 06-21-2005, 06:57 PM   #30
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Not a fan of using an oil to clean tyres. To me, rubber and oil don't mix, so WD-40 is not so good in my opinion. I've heard of Simple Green working well for cleaning tyres, then applying the additive and baking it into the tyre, with some sort of absorbent material such as an old T-shirt strip or paper towel to absorb most of the excess GOOP!
I'm no expert though, as in my experience the additive hasn't made nearly as much difference as the cleaning has. The other rule to follow, is that the additive is only going to work well IF you have clean tyres. If they are dirty, then the additive will not work properly.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Traction Sauce:Good/Bad The Fog Northwest Racers 30 11-09-2012 04:43 PM
2 new jack the gripper traction sauce for sale twistedone R/C Items: For Sale/Trade 3 03-02-2008 04:21 AM
Stickum tire sauce, the best tire sauce for any tire any surface adootindotin Electric On-Road 86 12-16-2004 03:00 PM
Traction Sauce Toxicity. Is there a solution? The Fog Electric On-Road 17 02-09-2004 05:05 PM
