Old 06-20-2005, 10:46 AM   #1
Default VFS-1, Masami, Rayspeed, Hara Twister
Could anyone explain what is the difference between VFS-1, Masami, Rayspeed and Hara Twister ESC? Is it the same ESC with different software?
Tral is offline   Reply With Quote
Old 06-20-2005, 10:49 AM   #2
John_S's Avatar
its the same speed controller with different throttle and braking setups
John_S is offline   Reply With Quote
Old 06-20-2005, 10:54 AM   #3
I must choose between Masami version or Hara version or Novak GTX. Hara Twister is too expensive. Which one should i buy? Is it only one ESC Masami or there are few like Twister and Twister 2? Is Masami Hirosaka uses Masami ESC?
Old 06-20-2005, 11:10 AM   #4
axel's Avatar
I would get the gtx cause it's easy to progarm and has all the features i needed, the vfs-1 is a GREAT esc, just a little to technological adnavced for just club racing.
axel is offline   Reply With Quote
Old 06-20-2005, 11:55 AM   #5
VFS-1 Pro, Masami, Rayspeed, and Twister 2 are all the same speed controller, but with different initail settings. The original Twister is the same as the older VFS-2000.
KO PROPO Staff is offline   Reply With Quote
Old 06-20-2005, 12:06 PM   #6
Team Girth's Avatar
Default Twister
i just ordered the 2.1 and i wasnt going to cost that much.. how much have you seen it for.. maybe i can help you out here.
Team Girth is offline   Reply With Quote
Old 06-20-2005, 12:21 PM   #7
Around 210$. GTX is for 149$ and Masami is for 149$.
Old 06-20-2005, 01:17 PM   #8
rocketron's Avatar
Trader Rating: 16 (100%+)
VFS-1 Pro, Masami, Rayspeed, and Twister 2 are all very good (being the same) and with the hand held unti or the PC interface you can create untold number of profiles if you like. Very nice feature especially if the price is the same or even close. The GTX is also a very good esc just not as programable.
rocketron is offline   Reply With Quote
Old 06-23-2005, 08:18 PM   #9
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Which is best for stock racing? At speedtechrc.com the rayspeed and masami are 175.99 while gtx is only 149.99 i believe....
vi3tishduy is offline   Reply With Quote
Old 06-23-2005, 09:05 PM   #10
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
If your going to race stock stay away from the Masami version... The Rayspeed would be a bit better.... if you are going to buy the KO... . .
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽĩ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-23-2005, 09:33 PM   #11
DIMO's Avatar
Default Novak GTX
I would go the GTX, its is an easy to program esc and has a heap of power.
My mate has the Hara Twister 2 and it hammers to, but the Vfs-1Pro is heaps hard to setup properly, and im pretty sure you need a ko radio if you want it to work,
At the end of the day its up to you.
DIMO is offline   Reply With Quote
Old 06-23-2005, 10:30 PM   #12
no you don't need a KO radio. but sure a KO radio will help you
yellow15 is offline   Reply With Quote
Old 06-24-2005, 12:13 AM   #13
Is the hara twister the same as getting a ko vfs-1 comp and using the hara settings from the ko web site ?
Phenochilus is offline   Reply With Quote
Old 06-24-2005, 01:56 AM   #14
V12
V12's Avatar
Donīt know if the Hara settings from the KO website are the same as the ones programmed into the Twister 2. I think only someone having a Twister will know this as Hara will use different settings. But if you use that Hara setting from the website in all of that ESCīs they will work all the same. Beside that label on the case the only difference are the factory settings and price.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 06-24-2005, 12:52 PM   #15
Team Girth's Avatar
Ya i think he is right. I also know that the twister 2 has the old setting and the twister 2.1 has his new setting. also the 2.1 has a carbon case.
KO HARA TWISTER 2.1 ESC Like New !!! Sigearhead R/C Items: For Sale/Trade 5 11-07-2007 09:43 AM
Cyclone Hara edition and Hara Twister 2 speedo FUK_WRX Australia For Sale/Trade 5 10-25-2007 09:40 AM
KO VFS1/Twister2.1 Hara/Masami Ed. v0rtex Australia Wanted to Buy 5 08-02-2006 08:12 PM
KO, Hara, Masami Yokomo Speedo's harjo R/C Items: For Sale/Trade 12 06-29-2006 09:35 PM
200MM Painted Stratus Masami/Hara RAL R/C Items: For Sale/Trade 8 05-02-2006 12:51 PM
