Old 09-04-2013, 11:48 AM   #1
Default motor temp
where do you guys temp your motors??
& do you gage your temps off the can or inside the can
& what temps are you looking for
i temp the can & looking for 160*
but should we really be temping the inside?? look for under 200*
i just was wondering about this
starrx is offline   Reply With Quote
Old 09-04-2013, 12:29 PM   #2
Skiddins's Avatar
I usually measure the can, on the opposite side to the fan.
But I will also try to get a measurement through the vent holes periodically to make sure that the inside is no more than around 10degC hotter than the can.
This way I know I'm extracting a lot of heat.
If there's a large difference in temp, the heat is getting trapped inside and no matter how powerful the fan you use, it's still going to build up where you don't want it.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-04-2013, 01:06 PM   #3
Skiddins
i wanna say my inside the can temps are like 10 to 15* hotter maybe even
20*...ill check tomorrow at practice
Old 09-04-2013, 03:35 PM   #4
Adam B's Avatar
Von, always temp opposite of the fan. I personally like a temp of 130ish degrees. But I will tolerate 160 as long as the motor does not fade. But temps can vary greatly by motor. For example it seems Revtec motors like to be ran warmer.
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 09-04-2013, 03:53 PM   #5
i guess my thinking was...imma start temping the inside da can & go by that temp to gear or time it
Old 09-04-2013, 04:53 PM   #6
asc6000's Avatar
Trader Rating: 15 (100%+)
each motor/car/setup will have it's unique hotspots
do be consistent where you measure per rule one
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
